Browse Forums Building A New House Re: Metricon Winchester 28- Landscaping 1361May 05, 2019 11:00 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1368Jun 13, 2019 9:05 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1370Jun 13, 2019 11:41 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1372Jun 14, 2019 10:09 am We've decided to open a case with customer care. Hopefully we get the resolution we're after. Re: Metricon Winchester 28- Landscaping 1373Jun 23, 2019 5:27 pm Sorry to hear all the problems with M. We got most our defects fixed except the crack lines on our garage floor. M said they will only repair if the crack is the size where you can slip in your credit card. We just need to monitor that. By the way Blackcat, does the double glazing windows work in winter? How's the temperature in your house? We didn't have that done but would like to know whether it is worth to change in future. The weather is freezing cold now and we are having 15° inside the house. Thanks in advance. Re: Metricon Winchester 28- Landscaping 1374Jun 23, 2019 5:44 pm Kimmykim Sorry to hear all the problems with M. We got most our defects fixed except the crack lines on our garage floor. M said they will only repair if the crack is the size where you can slip in your credit card. We just need to monitor that. By the way Blackcat, does the double glazing windows work in winter? How's the temperature in your house? We didn't have that done but would like to know whether it is worth to change in future. The weather is freezing cold now and we are having 15° inside the house. Thanks in advance. Re: Metricon Winchester 28- Landscaping 1376Jun 23, 2019 5:54 pm blackcat20 Kimmykim Sorry to hear all the problems with M. We got most our defects fixed except the crack lines on our garage floor. M said they will only repair if the crack is the size where you can slip in your credit card. We just need to monitor that. By the way Blackcat, does the double glazing windows work in winter? How's the temperature in your house? We didn't have that done but would like to know whether it is worth to change in future. The weather is freezing cold now and we are having 15° inside the house. Thanks in advance. Thanks! I bet the noise is also another thing for us. The rear and side of our house are all having construction now. I can hear all sort of sounds from the construction. Re: Metricon Winchester 28- Landscaping 1377Jun 23, 2019 6:01 pm Kimmykim blackcat20 Kimmykim Sorry to hear all the problems with M. We got most our defects fixed except the crack lines on our garage floor. M said they will only repair if the crack is the size where you can slip in your credit card. We just need to monitor that. By the way Blackcat, does the double glazing windows work in winter? How's the temperature in your house? We didn't have that done but would like to know whether it is worth to change in future. The weather is freezing cold now and we are having 15° inside the house. Thanks in advance. Thanks! I bet the noise is also another thing for us. The rear and side of our house are all having construction now. I can hear all sort of sounds from the construction. Re: Metricon Winchester 28- Landscaping 1379Jun 24, 2019 9:01 am MyFirst What's the temperature inside the house before heater was turned on this morning for u all in Melbourne. Im find it a bit underwhelmed with 6 stars home. Probably expecting too much Re: Metricon Winchester 28- Landscaping 1380Jul 10, 2019 5:03 pm Now going around in circles with customer care. They say defects weren't noted at PCI (they weren't there at that time), and that we caused them. I'd like to know how I eroded a window and caused two long deep straight cuts in the carpet They're also apparently happy with the sloppy paintwork. Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7867 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35332 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13647 |
