Browse Forums General Discussion Re: Drainage Issues along new concrete walkway 2Jun 14, 2019 10:00 am Frustrated lady Welcome to the forum I suggest you check your engineering Drawings for Compliant Drainage details Then cross check with whats in the contract and what's been build and post back hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Drainage Issues along new concrete walkway 4Jun 14, 2019 5:39 pm StructuralBIMGuy @Frustrated lady Welcome to the forum I suggest you check your engineering Drawings for Compliant Drainage details Then cross check with whats in the contract and what's been build and post back hth This post is very helpful especially for me. Thanks. Re: Drainage Issues along new concrete walkway 5Jun 14, 2019 6:00 pm 90Xmcrnetique StructuralBIMGuy @Frustrated lady Welcome to the forum I suggest you check your engineering Drawings for Compliant Drainage details Then cross check with whats in the contract and what's been build and post back hth This post is very helpful especially for me. Thanks. Thanks and welcome to the forum You might want to tag me/ heads up my up coming posts on BIM, Data and Bosch are going to be very useful for those building Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Drainage Issues along new concrete walkway 7Jun 18, 2019 10:11 am alexp79 Isn't it a drainage pit on the first photo in the lower bottom corner? yes it is. however he suppose to install a drainage pipe under the new concrete so the water runs under the concrete and not over it. reckon he forgot to do it and realised too late, as after the job is done, we found a long pipe in our yard with none of the contractors claiming it. Re: Drainage Issues along new concrete walkway 8Jun 18, 2019 10:15 am StructuralBIMGuy @Frustrated lady Welcome to the forum I suggest you check your engineering Drawings for Compliant Drainage details Then cross check with whats in the contract and what's been build and post back hah unfortunately there isn't an engineering drawing done for this job. initially just for concreting our new carport, however job extended to do new walkway to the front door with new drainage as the original drainage was an exposed curved drain along the house. so he said he will install a new drainage pipe under the new concrete he's pouring. but after the job is done, we found a long PVC pipe unused in the yard. the only thing he did is install a drainage pit, but that couldn't have cost $500, could it? Re: Drainage Issues along new concrete walkway 9Jun 18, 2019 11:59 am frustrated lady the only thing he did is install a drainage pit Have you taken the cover off to see if there is an outlet pipe? The set up looks amateurish but maybe that is how they do things where you are. Are you in QLD? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage Issues along new concrete walkway 10Jun 18, 2019 12:50 pm yes we are in QLD. there is an outlet pipe as the original drainage was there. do you think i can submit a complaint with the QBCC for defective work? Re: Drainage Issues along new concrete walkway 11Jun 18, 2019 1:50 pm frustrated lady do you think i can submit a complaint with the QBCC for defective work? The NCC does not require stormwater to be discharged from the property and there even isn't the requirement to have gutters and downpipes but the water must not overflow to neighbouring properties. What you have is unlikely to be considered defective. Your complaint is more about not receiving what was agreed but when you are quoted for work, you need to get a written quote that describes the job and which preferably has diagrams. You need to speak on site to a local plumber about the issue and find out just what has been done and act on his information and possible advice. I can't tell from where I am what has and hasn't been done. Good luck. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 7345 Hi there everyone i was hoping to get some details and some clarification on some potential defects that may have occurred our recent bathroom renovation. 1. There seems… 0 7324 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 8381 |
