Browse Forums Building A New House Re: Metricon Winchester 28- Landscaping 1361May 05, 2019 11:00 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1368Jun 13, 2019 9:05 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1370Jun 13, 2019 11:41 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1371Jun 14, 2019 7:42 am Drew01 blackcat20 Drew01 [quote="blackcat20"]Ensuite tiling has been redone, no more cracks. Now if only I could get the last few things fixed was told during the service the painters would be back to fix their work, only for our admin to tell us it was disqualified. Seems rather arbitrary what they will and won't fix. About to go to head of construction and crack it ... I want the damaged carpet repaired (not even replaced), paint work touched up, and the gouge in the stacker door glass fixed. And that's ignoring the damaged stacker handle and the dents in our colorbond roof. Would love a contact if you have one. JM? I'm calling our maintenance inspector tomorrow about it, because I really want to avoid them having to rip out the family room ceiling if I can. Also going to raise the whole grout not being the colour we chose/ordered now I see Renman had all his redone... We've got a leaking door, scratched garage door, dented roof sheet, damaged window frame that might need the side taken off the house to repair, and a bunch of other things they've gone quiet on [/quote]Ah not the same person. I don't have the details for the person that did the service, it was in the flurry just before I had the baby and wasn't high priority. Re: Metricon Winchester 28- Landscaping 1372Jun 14, 2019 10:09 am We've decided to open a case with customer care. Hopefully we get the resolution we're after. Re: Metricon Winchester 28- Landscaping 1373Jun 23, 2019 5:27 pm Sorry to hear all the problems with M. We got most our defects fixed except the crack lines on our garage floor. M said they will only repair if the crack is the size where you can slip in your credit card. We just need to monitor that. By the way Blackcat, does the double glazing windows work in winter? How's the temperature in your house? We didn't have that done but would like to know whether it is worth to change in future. The weather is freezing cold now and we are having 15° inside the house. Thanks in advance. Re: Metricon Winchester 28- Landscaping 1374Jun 23, 2019 5:44 pm Kimmykim Sorry to hear all the problems with M. We got most our defects fixed except the crack lines on our garage floor. M said they will only repair if the crack is the size where you can slip in your credit card. We just need to monitor that. By the way Blackcat, does the double glazing windows work in winter? How's the temperature in your house? We didn't have that done but would like to know whether it is worth to change in future. The weather is freezing cold now and we are having 15° inside the house. Thanks in advance. Re: Metricon Winchester 28- Landscaping 1376Jun 23, 2019 5:54 pm blackcat20 Kimmykim Sorry to hear all the problems with M. We got most our defects fixed except the crack lines on our garage floor. M said they will only repair if the crack is the size where you can slip in your credit card. We just need to monitor that. By the way Blackcat, does the double glazing windows work in winter? How's the temperature in your house? We didn't have that done but would like to know whether it is worth to change in future. The weather is freezing cold now and we are having 15° inside the house. Thanks in advance. Thanks! I bet the noise is also another thing for us. The rear and side of our house are all having construction now. I can hear all sort of sounds from the construction. Re: Metricon Winchester 28- Landscaping 1377Jun 23, 2019 6:01 pm Kimmykim blackcat20 Kimmykim Sorry to hear all the problems with M. We got most our defects fixed except the crack lines on our garage floor. M said they will only repair if the crack is the size where you can slip in your credit card. We just need to monitor that. By the way Blackcat, does the double glazing windows work in winter? How's the temperature in your house? We didn't have that done but would like to know whether it is worth to change in future. The weather is freezing cold now and we are having 15° inside the house. Thanks in advance. Thanks! I bet the noise is also another thing for us. The rear and side of our house are all having construction now. I can hear all sort of sounds from the construction. Re: Metricon Winchester 28- Landscaping 1379Jun 24, 2019 9:01 am MyFirst What's the temperature inside the house before heater was turned on this morning for u all in Melbourne. Im find it a bit underwhelmed with 6 stars home. Probably expecting too much Re: Metricon Winchester 28- Landscaping 1380Jul 10, 2019 5:03 pm Now going around in circles with customer care. They say defects weren't noted at PCI (they weren't there at that time), and that we caused them. I'd like to know how I eroded a window and caused two long deep straight cuts in the carpet They're also apparently happy with the sloppy paintwork. Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7861 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35329 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13644 |
