Browse Forums Building A New House Re: Shelf in shower 2Jun 03, 2019 1:26 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Shelf in shower 4Jun 03, 2019 3:01 pm Bebbsy SejaeD why were you getting charged extra? its the same amount of tiles and material etc a tiny bit of extra labour to cut the tiles to fit strange The shower niches were costed at around $500 each, something to do with having to install a double wall. Hence why we are looking to install some other kind of shelf within the shower recess. Lol a builder scam. I am sort of in the industry which is why I find it funny to see tricky ways builders try to extract more money, such as excessive site costs and and drop edge beams etc A shower niche is simply created by leaving a gap between the studs and noggins and then sheeting the recess or niche which is then waterproofed and tiled. Anyway, I know that doesnt help your current situation so sorry to hear Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Shelf in shower 5Jun 04, 2019 11:53 am We had PomD'or Metric "soap dishes" installed, available in several sizes: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Googling for info shows something from one supplier here. Chosen partially because the shelf lifts out for cleaning, and the rail stops things falling off. The ones we've got are about 20cm long so will fit a shower-gel, a shampoo & a conditioner next to each other; we've two stacked one-above-the-other above the shower mixer-taps, and in the main & ensuite we have another near the shower-head. Re: Shelf in shower 6Jun 04, 2019 2:07 pm SejaeD Bebbsy SejaeD why were you getting charged extra? its the same amount of tiles and material etc a tiny bit of extra labour to cut the tiles to fit strange The shower niches were costed at around $500 each, something to do with having to install a double wall. Hence why we are looking to install some other kind of shelf within the shower recess. Lol a builder scam. I am sort of in the industry which is why I find it funny to see tricky ways builders try to extract more money, such as excessive site costs and and drop edge beams etc A shower niche is simply created by leaving a gap between the studs and noggins and then sheeting the recess or niche which is then waterproofed and tiled. Anyway, I know that doesnt help your current situation so sorry to hear OP is most likely in WA, so builders quote is about right as brickie will need to do extra leaf of bricks for shower niche. Re: Shelf in shower 7Jun 04, 2019 2:49 pm Forg We had PomD'or Metric "soap dishes" installed, available in several sizes: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Googling for info shows something from one supplier here. Chosen partially because the shelf lifts out for cleaning, and the rail stops things falling off. The ones we've got are about 20cm long so will fit a shower-gel, a shampoo & a conditioner next to each other; we've two stacked one-above-the-other above the shower mixer-taps, and in the main & ensuite we have another near the shower-head. Thx, looks great. How does it install? (I checked the website but no clues there) Re: Shelf in shower 8Jun 04, 2019 6:25 pm I didn't do it myself so unsure, but I assume they make sure there's some wooden frame at the correct height behind the waterproof gyprock, then when tiling is done they drill holes through the tiles & use screws into the wooden frame. Re: Shelf in shower 9Jun 04, 2019 11:44 pm Forg I didn't do it myself so unsure, but I assume they make sure there's some wooden frame at the correct height behind the waterproof gyprock, then when tiling is done they drill holes through the tiles & use screws into the wooden frame. Cheers for that. 😀 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9564 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5843 Ask yourself if the insurance company will be aware of the Reno. 4 7370 |
