Browse Forums Owner Builder Forum Re: Newbie owner/builder - building surveyor questions 2Jun 02, 2019 9:23 am Dreyfus I've just got the plans through council to build a 116m2 shed out of 200mm thick colorbond sandwich panel (like a big cool room / R value of 10 for insulation) on concrete slab.....live in a part of the shed in a few years time Welcome to the forum You will need to update the planning and building applications to suit Dreyfus Another question is, I'm wanting to have a passive air flow system in each room for the wine. Where there is a 250mm wide pipe that will zig-zag under the garden using the soil temperature to cool the air before it draws in to the wine storage rooms for summer. Will the surveyor allow these large vent holes coming up from the slab into each room (2 vents per room)?? research Ground Temperature Recovery Systems The calculations/proofs are done using the Engineering BIM 3D Model and Multiphysics simulations (Yet another reason why Engineering BIM with data Is Superior to Architectural BIM) The Building Surveyor should certify what the engineer has provided/approved Goodluck Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs You should check your detail drawings, it may show downpipe within brick pier. 14 14099 Hi VK, I am now retired however I have stood beside over 300 owner builders in the past 18 years that have successfully built their own homes. First of all a building… 10 22670 |
