Browse Forums Building A New House Re: Brand new house - Rising damp issue 21May 29, 2019 9:19 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Brand new house - Rising damp issue 24May 29, 2019 9:51 pm Joker saveH20 s find out who's bricks they are is a must and can be done easily, either ask agent for builders contact details or take a spare brick to boral,austral,nubrik, almost certainly will be one of the above,have seen a very similar if not the same range from boral, manufacturers generally are very knowledgeable on their products and problems ,but ask like you know what your talking about or they can or could cover themselves. Sure, I can give it a try tomorrow. But no one seems to be answering my question which is about who is the best person to inspect the damp and give me a verdict ?? I have called the damp experts, they say they don't do pre inspections tests, the plumber says it's not their turf. This is very stressful. The building inspector says just specialist and doesn't reveal much. Re: Brand new house - Rising damp issue 26May 29, 2019 10:29 pm Joker To find out who if anyone ,you need brick manufacturers,they will answer if bricks have been correctly built according to their instructions and if theirs a problem with bricks. Ok, I will speak to agent and find out what brick it is Re: Brand new house - Rising damp issue 27May 30, 2019 9:43 pm If you are in Melbourne I can assist you Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Brand new house - Rising damp issue 29Jun 02, 2019 9:32 pm Hello All, Thank you so much for all your support and suggestion. I had a damp inspectors inspect and he confirmed its a raising damp issue and suggested a external drain along the perimeter of the external walls as the house was built on steep slope, waffle slabs, H1 soil . We decided to terminate the contract for our peace of mind (period). Re: Brand new house - Rising damp issue 31Jun 02, 2019 10:13 pm Not sure about the name of the tests, but he sort of focussed on the base of the walls, also he checked the drains of the house. He checked the bricks in other areas and confirmed that it's not bricks and apparently Qld bricks don't have salt content etc.... Final verdict was it is a raising damp issue Re: Brand new house - Rising damp issue 32Jun 02, 2019 10:26 pm I can only go back to what I noted in my first post about the concrete height but there is nothing like being onsite for visuals. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. I am in a difficult situation. Long story short I have been handed over my brand new home in Sydney with everything in the house being great except the windows that were… 0 941 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20586 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7791 |
