Browse Forums Building A New House Re: Is my potential double garage build too small? 5May 28, 2019 8:47 am Bobjane Hi, I asked for a big garage but this is what the builder sent to me. Is this too small? He was saying the size shown is the internal size and it’s 100mm bigger than the minimum requirements width wise. What do you guys think? We currently only have 2 small cars (toyota corollas) but you never know in the future. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Very tight garage, especially if you want to open your doors and get out! I agree that 6 x 6 should be a minimum otherwise there wont be any room to store tools or a lawnmower etc Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Is my potential double garage build too small? 6May 28, 2019 9:31 am Where are you building? As a building designer I know in QLD the Queensland Development Code (QDC) specifies the minimum requirements for a double garage to be 5.70m wide x 6.00m deep. Anything less is non compliant. However very few certifiers and draftspersons pick up on this... Check your local regulations because what's currently drawn I would consider unusable even with 2 small cars. Hope this helps, Laurence Re: Is my potential double garage build too small? 7May 28, 2019 9:37 am Thanks for the replies, ill ask if the builder could maybe shave some room off of the other rooms to make the garage 200mm bigger width wise so it comes to 5.7m internal (6.1m total) width wise. Re: Is my potential double garage build too small? 8May 28, 2019 9:40 am Apologies the scale threw me off! On closer inspection, the width of your garage is 5.75m wide excluding the engaged brick piers. Depth is 6.41m so you'll have approximately half a meter of storage area to the rear of your garage. One question, is the storage area a covenant requirement? If so the assessor may calculate it differently to what is shown (allowing 6.0m for the depth of the garage and the remainder as storage). Again depends where you're building. Re: Is my potential double garage build too small? 9May 28, 2019 10:36 am [quote="l_vanslyke":25rilsp4]Apologies the scale threw me off! On closer inspection, the width of your garage is 5.75m wide excluding the engaged brick piers. Depth is 6.41m so you'll have approximately half a meter of storage area to the rear of your garage. One question, is the storage area a covenant requirement? If so the assessor may calculate it differently to what is shown (allowing 6.0m for the depth of the garage and the remainder as storage). Again depends where you're building.[/quote:25rilsp4] Yes storage is a council requirement. Only issue i have if i make the garage 200mm bigger, where would i get that extra space, the rooms are already pretty small ;( [img:3tldood7]https://forum.homeone.com.au/u/89639_1559003959.jpeg[/img:3tldood7] Re: Is my potential double garage build too small? 10May 28, 2019 12:16 pm I find some double garages are almost impossible to get two cars into due to small garage doors,we went for bd widest width door which allows you to use more of your garages width,many I have seen don't park two cars in due to garage door width. Re: Is my potential double garage build too small? 11May 28, 2019 12:58 pm Joker I find some double garages are almost impossible to get two cars into due to small garage doors,we went for bd widest width door which allows you to use more of your garages width,many I have seen don't park two cars in due to garage door width. I guess optimal door width should be around 4.8-5.0 m? Re: Is my potential double garage build too small? 12May 28, 2019 1:19 pm alexp79 Joker I find some double garages are almost impossible to get two cars into due to small garage doors,we went for bd widest width door which allows you to use more of your garages width,many I have seen don't park two cars in due to garage door width. I guess optimal door width should be around 4.8-5.0 m? Correct, standard would be 4.8m wide. Re: Is my potential double garage build too small? 13May 28, 2019 3:20 pm l_vanslyke alexp79 Joker I find some double garages are almost impossible to get two cars into due to small garage doors,we went for bd widest width door which allows you to use more of your garages width,many I have seen don't park two cars in due to garage door width. I guess optimal door width should be around 4.8-5.0 m? Correct, standard would be 4.8m wide. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Okay the builder will now take 10cm off BED2 to add 10cm to the garage. Garage will now be 6.00 x 6.80. Bedroom 2 will be a bit tight but I think the extra space in the garage will be worth it. You guys mentioned 4.8m is the standard garage door width, however should i get a 5m wide garage door since the garage will now be 6m wide? any thoughts? Re: Is my potential double garage build too small? 14May 28, 2019 3:45 pm Bobjane l_vanslyke alexp79 [quote="Joker"]I find some double garages are almost impossible to get two cars into due to small garage doors,we went for bd widest width door which allows you to use more of your garages width,many I have seen don't park two cars in due to garage door width. I guess optimal door width should be around 4.8-5.0 m? Correct, standard would be 4.8m wide. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Okay the builder will now take 10cm off BED2 to add 10cm to the garage. Garage will now be 6.00 x 6.80. Bedroom 2 will be a bit tight but I think the extra space in the garage will be worth it. You guys mentioned 4.8m is the standard garage door width, however should i get a 5m wide garage door since the garage will now be 6m wide? any thoughts?[/quote]Absolutely wider door or bigger garage will be in vain. Re: Is my potential double garage build too small? 15May 28, 2019 4:33 pm I reckon the garage door is already close to 5.0m wide. I'd also put a door out the back of the garage. It makes it easier to get gardening equipment and supplies to the back of the house rather than walking around. Best bet is to have an opening and put a small roller door on it. It will be a wider opening and save you on going maintenance for a standard door. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Is my potential double garage build too small? 16May 28, 2019 6:54 pm Minimum double garage width according to Australian standards is 5.4x5.4m. Generally you allow 2.4m width for the car plus 30cm clearance between cars and walls. More space makes a big difference though. Re: Is my potential double garage build too small? 17Sep 04, 2020 8:25 pm [quote="Bobjane":dwhsl0if]You guys mentioned 4.8m is the standard garage door width, however should i get a 5m wide garage door since the garage will now be 6m wide? any thoughts?[/quote:dwhsl0if] Where did you end up with on the garage door width. Our garage in our planned build is also 6.0 wide by 6.5 deep and our plans show a 4800 wide door. Thinking this needs to be wider but don't have any experience with double doors to base this off. Also curious to how it will look visually. Follow my build here: https://www.instagram.com/ivy5custom Re: Is my potential double garage build too small? 19Sep 04, 2020 9:05 pm Pulse 4.8m door is ok for a nice straight driveway, if you need to swing in at all an extra 300mm will really help Thanks. We have the room and capacity to widen the door but also don't want to do it of 4.8 is more than enough. We aren't a perfectly straight driveway but I don't think we'd have much issue with needing to swing in at all. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Follow my build here: https://www.instagram.com/ivy5custom Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2675 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8238 Just removed 40 liters of water in the span of 2 hours. Water fills up the hole just above the seepage point and doesn't overflow. 1 960 |
