Browse Forums Paving & Concreting Re: Concrete, weep holes and window sills 21May 14, 2019 7:17 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete, weep holes and window sills 22May 18, 2019 5:29 pm It's certainly more course than I was expecting, and a departure from the finish of the original driveway. Although I wasn't sure I had much ground to complain if all that was described was "plain concrete". Afraid that ship may have sailed by now. Consumer affairs has advised me to take it straight to VCAT as a goods and services claim (rather than via DBDRV for a building dispute). I've also recently reported him to VBA for infringements of the Contracts Act, as I advised him I would. Re: Concrete, weep holes and window sills 23May 18, 2019 6:04 pm Have you formally rejected his offer? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11294 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7212 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5548 |
