Browse Forums Building A New House Re: House slab is exposed all along the sides. Is this right 3May 12, 2019 10:17 pm eltkris Just wondering if anyone can shed some light on this. We have been in our house for 6 months now. We spoke to a Landscaper who also has experience in the building industry. He said that our builder should not have left our Slab exposed the way that it is. As you can see below, they left the bottom of our house all around the slab exposed like this, so you can see the black plastic, and in many areas the plastic has torn away and the slab itself is exposed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ On top of that, you can see they placed our Hot water unit on a bunch of Bricks instead of on a proper concrete slab. Our landscaper was surprised that we were given an Occupancy Permit. The inspector that gave the permit didn't seem to have any issue with this. The only thing he said that had to be done, was that the ground had to be raised at all of our entry points so that the step down isn't too much. So that's what the builder did. Does anyone else's new house build look like this? Have they failed to meet some code or regulation that I can raise with them? I'm wondering if there's anything I can do to make the builder bring in soil to raise it all. We're now having to spend more money on soil for our landscaping to effectively raise the land all around our house. U should be happy mate. The slab membrane is so perfect. Never seen a completed house with such perfect slab membrane. And expose slab edge. Yes is normal most builder just leave it. Some will just cover it up with some token soil. But at the end of the day landscaping will cover it up. However what I just learned recently. U are suppose to leave at least 50mm of your slab edge so u can see termite attack. However nobody wants to do this though since its ugly. Re: House slab is exposed all along the sides. Is this right 4May 12, 2019 10:36 pm MyFirst just so your aware for your own property, a minimum of 75mm exposed slab edge is the magic number per AS3660.1... however most pest inspectors will tell you 80mm-100mm. The standard notes you only require one method of protection (ie. Case of a building perimeter - either exposed slab edge, perimeter chemical impregnated sheet, in soil chemical barrier by way of refillable reticulation system, etc). Rhys Re: House slab is exposed all along the sides. Is this right 5May 22, 2019 11:58 am Thanks for the replies, everyone. Glad to hear that's pretty normal. This is the second house we have built, and our last one they did not leave it like this. Now it makes sense, because they actually didn't use any termite protection at all. I guess their method of protection, is leaving the exposed slab edge and expecting that we won't cover it up. I'm not surprised. Re: House slab is exposed all along the sides. Is this right 6May 22, 2019 1:28 pm eltkris Thanks for the replies, everyone. Glad to hear that's pretty normal. This is the second house we have built, and our last one they did not leave it like this. Now it makes sense, because they actually didn't use any termite protection at all. I guess their method of protection, is leaving the exposed slab edge and expecting that we won't cover it up. I'm not surprised. my money is on that plastic being a form of termite treatment, AS 3660.1.2000 requires all homes to have an approved form of termite treatment. Would be interesting to see what the writing is on the plastic Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: House slab is exposed all along the sides. Is this right 7May 22, 2019 2:10 pm [quote="eltkris":358j09k3]Thanks for the replies, everyone. Glad to hear that's pretty normal. This is the second house we have built, and our last one they did not leave it like this. Now it makes sense, because they actually didn't use any termite protection at all. I guess their method of protection, is leaving the exposed slab edge and expecting that we won't cover it up. I'm not surprised.[/quote:358j09k3] Has the builder confirmed that no termite protection has been installed? Could you confirm the makeup of your dwelling? Brick veneer, double brick, combination over two floors? Assumed timber frame roof? If no 'structural' timber is located in the dwelling, then technically no requirement to comply with AS3660. Otherwise, at a minimum you should have the 75mm 'exposed' slab edge right around the perimeter (cut plastic and expose slab edge). Services penetrating the slab should also be fitted with rated collars to prevent termite entry that way. Alternatively as mentioned above, the DPM may be impregnated with appropriate chemicals per the Standard, so all OK as the entire underside of the slab (whole building) is protected. Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7795 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10916 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10415 |
