Browse Forums Building A New House Re: Our first home build Sorrento 39 with Carlisle homes 5May 10, 2019 10:30 am Mark Armstrong BSc (Eng) MIEAust CPEng Development Manager http://www.katanafoundations.com.au http://www.polyvoid.com.au http://www.biax.com.au Re: Our first home build Sorrento 39 with Carlisle homes 10May 11, 2019 8:14 am shokel1975 Congrats Ramee! Enjoy the ride! Thanks a lot! shokel1975 looking forward for the next steps! Re: Our first home build Sorrento 39 with Carlisle homes 11May 11, 2019 8:18 am Macher Ramee, is site start the day of site scrape? I'm interested when the clock starts ticking for C. I am not 100% sure Macher, But they seams to be on time so lets see. This is a link I found about site start date http://anewhouse.com.au/2012/08/contracts-contract-period/ Site start day is basically when actual building work started so site clearing day it is. According to our HIA contract builder should complete house within 308 days from site start date (including all the holidays and other delays due to weather etc) Re: Our first home build Sorrento 39 with Carlisle homes 12May 13, 2019 2:27 pm Ramee Engineer Hi Ramee Did the builder ever consider screw piles to a depth beyond the influence of the trees? Cheers Mark Hi Mark, Yes they have included lots of screw piles in their design. They have recommended 2.3m minimum depth or go deep until 75KN working load is achieved in their design. I believe this is due to soil report came as P class due to soft top fill of the land development. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the diagram of proposed slab design with all the black dots are screw piles. OK, that looks good - ask if you can have the pile installation logs to make sure the piling contractor went down 2.3m - actually if you can spend the time to watch some of the piling being done - it is one of the most important parts of the build Mark Armstrong BSc (Eng) MIEAust CPEng Development Manager http://www.katanafoundations.com.au http://www.polyvoid.com.au http://www.biax.com.au Re: Our first home build Sorrento 39 with Carlisle homes 13May 15, 2019 9:39 pm Engineer OK, that looks good - ask if you can have the pile installation logs to make sure the piling contractor went down 2.3m - actually if you can spend the time to watch some of the piling being done - it is one of the most important parts of the build Thanks! I will try to get the pile installation logs from C but so far couldn't get hold of the SS. Re: Our first home build Sorrento 39 with Carlisle homes 14May 15, 2019 9:44 pm Today went to see the construction site to see some screw pile action but it was already done and gone when I arrived. They must have done really quick or start very early considering amount of piles have to screw in to the ground! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home build Sorrento 39 with Carlisle homes 16May 17, 2019 10:03 am Ramee Today went to see the construction site to see some screw pile action but it was already done and gone when I arrived. They must have done really quick or start very early considering amount of piles have to screw in to the ground! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You should be able to put a tape measure down the piles and confirm they all go to the correct depth - what depth is natural ground? Mark Armstrong BSc (Eng) MIEAust CPEng Development Manager http://www.katanafoundations.com.au http://www.polyvoid.com.au http://www.biax.com.au Re: Our first home build Sorrento 39 with Carlisle homes 18May 17, 2019 5:51 pm Engineer You should be able to put a tape measure down the piles and confirm they all go to the correct depth - what depth is natural ground? From borehole logs from soil test report, one borehole data reports natural sand start around 1m mark. Other four boreholes data reports 30cm to 50cm deep from surface. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I managed to get the screw pile data logs as well. There are totally 48 screw piles all going same depth of 4m with apparently 2 helix design? All record same SWL and Nm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home build Sorrento 39 with Carlisle homes 19May 17, 2019 6:24 pm Macher Looks like we are in sync. Same day site start and today we had drains installed too. Slab pour scheduled next Thursday! Hi Macher, Oh that is great news! Yes our slab pour is scheduled on next Thursday as well..! I didn't see your build thread until now! Your's going to be really great house! Congrats!! Hoping both out slab pours go according to the plan! Re: Our first home build Sorrento 39 with Carlisle homes 20May 20, 2019 8:58 am Ramee Engineer You should be able to put a tape measure down the piles and confirm they all go to the correct depth - what depth is natural ground? From borehole logs from soil test report, one borehole data reports natural sand start around 1m mark. Other four boreholes data reports 30cm to 50cm deep from surface. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I managed to get the screw pile data logs as well. There are totally 48 screw piles all going same depth of 4m with apparently 2 helix design? All record same SWL and Nm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looks good - not sure how you get exactly the same reading on every pile at 4.0m as there will always be a bit of variation - but on the face of it - it looks good. Mark Armstrong BSc (Eng) MIEAust CPEng Development Manager http://www.katanafoundations.com.au http://www.polyvoid.com.au http://www.biax.com.au So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27712 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37142 Carlisle use to sneak a water resistant "Performance Solution" into their contracts. Have you checked your contract for same? 4 10209 |
