Same, same but different?
https://www.maseslighting.com.au/led-ba ... -lighting/
https://www.bestbuylighting.com.au/led/led-batten.html
Thanks for the lights. Any suggestion on fan heat light 3in1??
Browse Forums Building A New House Re: Coral Homes general build thread 11433May 10, 2019 1:56 pm Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 11434May 10, 2019 2:02 pm MrsAJ Anyone to guide me please on the driveway???!!! On that note we just came to know landscaping is very very expensive and some people dont want to take a project less than $15000 🙁🙊🙉 Did you have similar experience with landscaping? Unless you have to get it done, hold off. You can just put grass down and some edging until you can figure out what you want and save up. Yes, landscaping is quite expensive and landscapers do charge a premium. Depending if it is for ALL the property front back and sides, that doesn't seem too bad. Good quality turf is quite expensive. Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 11435May 10, 2019 2:05 pm Corallake MrsAJ Hi All, What are the things needs to be considered while putting driveway. Is sealant required?? Should we put driveway till the leftmost end or just leave it for grass space? Anything else we need to thing off?? Depending on the finish you get on your driveway, there will be maintenance. Generally, if it is painted finish it should get a sealant over it to protect it. The sealant is done after the paint finish has dried. Do not drive over it for a week. It needs to cure My neighbours drove over it within a few days and the tyres left patches where the sealant and paint came up. We have aggregate. Once that dried it was sealed. We could not drive on it for a week. We were told to give it a light spray with stuff after 6 months then another coat of seal after 12 months. It was quite easy. With both finished though it is suggested that a reseal (you can buy a kit and is rolled on with a roller) is redone every two years. Make sure the driveway reaches the side of the house and not just garage width. Thank you so much for your reply Corallake It's very helpful and we will note it down. We are planning to do exposed aggregate. We have this drain kind of thing on pathway to the left of our driveway and the person said it is better to skip that else if they damage while doing driveway we will have to pay for it. Re: Coral Homes general build thread 11436May 10, 2019 2:08 pm MrsAJ Corallake MrsAJ Hi All, What are the things needs to be considered while putting driveway. Is sealant required?? Should we put driveway till the leftmost end or just leave it for grass space? Anything else we need to thing off?? Depending on the finish you get on your driveway, there will be maintenance. Generally, if it is painted finish it should get a sealant over it to protect it. The sealant is done after the paint finish has dried. Do not drive over it for a week. It needs to cure My neighbours drove over it within a few days and the tyres left patches where the sealant and paint came up. We have aggregate. Once that dried it was sealed. We could not drive on it for a week. We were told to give it a light spray with stuff after 6 months then another coat of seal after 12 months. It was quite easy. With both finished though it is suggested that a reseal (you can buy a kit and is rolled on with a roller) is redone every two years. Make sure the driveway reaches the side of the house and not just garage width. Thank you so much for your reply Corallake It's very helpful and we will note it down. We are planning to do exposed aggregate. We have this drain kind of thing on pathway to the left of our driveway and the person said it is better to skip that else if they damage while doing driveway we will have to pay for it. We have two right in the middle of the driveway one at the top one at the bottom our driveway is about 22 metres. It didn't bother our concreter. He just made sure the pipes were all good. Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 11438May 11, 2019 10:12 am If you go here: https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&start=860 It should take you to page 44 on my site on Homeone. Our driveway was about 125sqm and cost $20K. Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 11439May 12, 2019 8:21 pm Corallake If you go here: https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&start=860 It should take you to page 44 on my site on Homeone. Our driveway was about 125sqm and cost $20K. Thank you so much. I will surely have a look. You should check your detail drawings, it may show downpipe within brick pier. 14 14078 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13745 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 1766 |
