Browse Forums Building A New House Re: Custom build Sydney Hills with attached granny flat 96May 08, 2019 8:21 pm hillsbuilds please do. I am loving it. They are amazing out there. And I am learning a lot. Custom build Sydney Hills with attached granny flat 97May 23, 2019 7:38 am Finally, Most of our windows arrived this week. Loving the louvres! Carpenters were around to install. I’m curious to know how they get the larger windows upstairs. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Custom build Sydney Hills with attached granny flat 98May 23, 2019 11:05 am Custom build Sydney Hills with attached granny flat 99May 23, 2019 12:06 pm Thinking a bit more about it, SMH I should have just gone for normal sliders with one fixed pane and one moving pane. These ones we’ve got, with two moving panes and one fixed, means that the widest I can open the window will be a third of the width! Whereas with the former I would be able to open the window to half the width. Plus the way these are I’ll have to pay for more insect/security screening. Although in the other hand I guess I will be able to make two openings per window which will hopefully aid in airflow. Re: Custom build Sydney Hills with attached granny flat 100May 23, 2019 2:45 pm Your build progress and quality looks good from the images. Hey are those awnings AWS 517 series? Look similar frame design to some of ours. Do you have a sliding door as well? We are currently in a bit of a battle with builder and fabricator because the frame on our magnum sliding door is really crap. Would be good to get a comparison of some of the joins around the frame. --------------------------------------------------------------------- Check our Homeone build blog here Hi all, Been browsing project builders' website and saw Masterton with attached granny flat design Seeing bad reviews from masterton in this website/facebook, does… 0 18300 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4106 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13890 |
