Browse Forums Building A New House Re: Alfresco Decking min step down requirments 3May 08, 2019 7:37 am gillybean Yeah if you say it’s 70mm step down that would allow 45x90mm joists (laid flat so the 45mm is the height) and then your choice of deck over the top of them at approximately 22mm height. That total equates to about 67mm height so should work out mint. Awesome I wasn’t sure how small you can get joists so that’s sweet thanks Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10970 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11829 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 1911 |
