Browse Forums General Discussion Re: Cracked Ceiling 3May 04, 2019 12:35 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Cracked Ceiling 6May 06, 2019 12:58 pm Saint Mike building-expert The most likely cause is the ground movement, either slab edge subsidence or slab centre heave causing tension in the ceiling and cracking plaster. Would it keep happening though BE ? Surely the movement would be felt if it was continual ? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If it looks like the above 2 dwellings it is slab heave/subsidence Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4860 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8911 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5936 |
