Browse Forums Bathrooms and Laundry 1 May 06, 2019 12:28 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey all, in the bathroom, there is what looks like tape at the join between the wall and ceiling that's starting to come off. There is also a slight gap between the walling and ceiling, as ants have come through there before. My question is, how would I go about repairing this? This is right above the shower, so it does see quite a bit of moisture. Thanks in advance! Re: Repairing wall & ceiling join. 3May 06, 2019 3:17 pm I agree, it’s probably a metal angle. We have tiles that go to the ceiling too, but no hint that’s what our builder used at the join. You could get a competent plaster to refinish it, but it might happen again over time. Alternatively, install another layer of blue-board right to the edges or even install a cornice. Re: Repairing wall & ceiling join. 4May 07, 2019 9:58 pm Thanks for replying guys. I just had a close up look, and it's definitely not metal. Looks to be paper tape and possibly just painted over. Would using adhesive to stick it back down and paint over it be sufficient do you think? Re: Repairing wall & ceiling join. 5May 08, 2019 10:46 am simonjlee Thanks for replying guys. I just had a close up look, and it's definitely not metal. Looks to be paper tape and possibly just painted over. Would using adhesive to stick it back down and paint over it be sufficient do you think? Many things can be "sufficient", but if it was me I would want to fix it properly and permanently. I would get a plasterer in. Re: Repairing wall & ceiling join. 6Dec 12, 2019 6:23 pm It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17257 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5676 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6058 |
