Browse Forums Building A New House 1 Apr 19, 2017 1:13 am Re: Simonds Prague with Modifications in Melbourne's North 4Apr 19, 2017 6:15 pm Building the simonds palisade in gippsland Re: Simonds Prague with Modifications in Melbourne's North 6May 04, 2019 10:46 pm Re: Simonds Prague with Modifications in Melbourne's North 7May 05, 2019 9:00 am Plan looks well laid out. Only minor thing I thought of was do you really need the WIP door? Not sure you would need to close it off because it’s obscured from view anyhow. Might be too late in the process though anyhow? Good luck with the build --------------------------------------------------------------------- Check our Homeone build blog here Re: Simonds Prague with Modifications in Melbourne's North 8Jun 13, 2019 11:38 pm darb74 Plan looks well laid out. Only minor thing I thought of was do you really need the WIP door? Not sure you would need to close it off because it’s obscured from view anyhow. Might be too late in the process though anyhow? Good luck with the build Thanks With regards to WIP door, you probably right, that door may end up open all the time. But that's fine, in case we'll have a pet dog one day, then that door would be useful Re: Simonds Prague with Modifications in Melbourne's North 10Jul 14, 2019 9:37 pm Re: Simonds Prague with Modifications in Melbourne's North 11Jul 16, 2019 2:08 pm Hi! your build looks amazing so far and the floor plan looks great! I am going to be building with Simonds too, i have contract signing next week. A bit nervous about the contract signing, do you think I have to be wary of anything? Do you have any tips or advice for new builders like m? Good luck for your build! I will be foloowing your thread! Re: Simonds Prague with Modifications in Melbourne's North 12Jul 16, 2019 3:43 pm Dui2705 A bit nervous about the contract signing, do you think I have to be wary of anything? Do you have any tips or advice for new builders like m? I know this question wasn't directed to me, but when we built with this same builder 10+ years ago they certainly don't like to give you much time prior to thoroughly go over all the details. Our current builder were much better in that we were emailed a draft contract a few days prior to signing, so I would try hard to get this done. Obviously you need to check over everything, as down the track the builder is always happy to refer back to your contract and say things like....'well, you signed the plans off and this was how it was drawn in'. Even things that don't actually make sense in reality...if it's on the plans that is how they will typically build it. So double check all our specifications and plans carefully. Make sure you check all elevations so things like cabinetry dimensions are what you want (eg. fridge cavity height, depth, width etc). Make sure your tiling (incl. splashbacks) is all properly marked on the plans. I would also confirm that the builder is going to be installing proper 'breathable' wall wrap (as per the recent changes since May 1 to the NCC)....many builders around here appear to be still using the foil backed wall wrap that doesn't allow water vapour to escape your wall cavities. Also ensure roof sarking is going to be layed underneath your tiles or metal roof. Whirly bird(s) getting installed? Check things like bricks above windows/doors? Many builders simply install linea board type products instead of bricks etc. Anyhow, just take your time to review it all and don't let them rush you. It's a lot of money involved and not theirs! Good luck --------------------------------------------------------------------- Check our Homeone build blog here Re: Simonds Prague with Modifications in Melbourne's North 13Jul 16, 2019 9:53 pm darb74 Dui2705 A bit nervous about the contract signing, do you think I have to be wary of anything? Do you have any tips or advice for new builders like m? I know this question wasn't directed to me, but when we built with this same builder 10+ years ago they certainly don't like to give you much time prior to thoroughly go over all the details. Our current builder were much better in that we were emailed a draft contract a few days prior to signing, so I would try hard to get this done. Obviously you need to check over everything, as down the track the builder is always happy to refer back to your contract and say things like....'well, you signed the plans off and this was how it was drawn in'. Even things that don't actually make sense in reality...if it's on the plans that is how they will typically build it. So double check all our specifications and plans carefully. Make sure you check all elevations so things like cabinetry dimensions are what you want (eg. fridge cavity height, depth, width etc). Make sure your tiling (incl. splashbacks) is all properly marked on the plans. I would also confirm that the builder is going to be installing proper 'breathable' wall wrap (as per the recent changes since May 1 to the NCC)....many builders around here appear to be still using the foil backed wall wrap that doesn't allow water vapour to escape your wall cavities. Also ensure roof sarking is going to be layed underneath your tiles or metal roof. Whirly bird(s) getting installed? Check things like bricks above windows/doors? Many builders simply install linea board type products instead of bricks etc. Anyhow, just take your time to review it all and don't let them rush you. It's a lot of money involved and not theirs! Good luck Wow! Thank you for this detailed response. I really appreciate everything you have set. I find it weird too, I have requested multiple times that I want the contract prior to signing, but they have just refused to give it to me. I don’t understand why it’s so hard for them to do this? I am going to request this again. I wasn’t aware of the breathable wall wraps, I’ll make a note of this and ask them. Will also check the sarking as I again am not sure about this at all. We have brick work over windows I think they are charging like $1800 for this. Thanks again for your suggestions. Re: Simonds Prague with Modifications in Melbourne's North 14Jul 17, 2019 12:02 am Dui2705 darb74 Dui2705 A bit nervous about the contract signing, do you think I have to be wary of anything? Do you have any tips or advice for new builders like m? I know this question wasn't directed to me, but when we built with this same builder 10+ years ago they certainly don't like to give you much time prior to thoroughly go over all the details. Our current builder were much better in that we were emailed a draft contract a few days prior to signing, so I would try hard to get this done. Obviously you need to check over everything, as down the track the builder is always happy to refer back to your contract and say things like....'well, you signed the plans off and this was how it was drawn in'. Even things that don't actually make sense in reality...if it's on the plans that is how they will typically build it. So double check all our specifications and plans carefully. Make sure you check all elevations so things like cabinetry dimensions are what you want (eg. fridge cavity height, depth, width etc). Make sure your tiling (incl. splashbacks) is all properly marked on the plans. I would also confirm that the builder is going to be installing proper 'breathable' wall wrap (as per the recent changes since May 1 to the NCC)....many builders around here appear to be still using the foil backed wall wrap that doesn't allow water vapour to escape your wall cavities. Also ensure roof sarking is going to be layed underneath your tiles or metal roof. Whirly bird(s) getting installed? Check things like bricks above windows/doors? Many builders simply install linea board type products instead of bricks etc. Anyhow, just take your time to review it all and don't let them rush you. It's a lot of money involved and not theirs! Good luck Wow! Thank you for this detailed response. I really appreciate everything you have set. I find it weird too, I have requested multiple times that I want the contract prior to signing, but they have just refused to give it to me. I don’t understand why it’s so hard for them to do this? I am going to request this again. I wasn’t aware of the breathable wall wraps, I’ll make a note of this and ask them. Will also check the sarking as I again am not sure about this at all. We have brick work over windows I think they are charging like $1800 for this. Thanks again for your suggestions. @Dui2705 In our case, we didn't spend too much time going into details during contract signing. Apart from the drawings, colours and itemized specifications, the rest of the content in the contract are boilerplate. Simonds Safety Requirements, Simonds Standard Building Specifications, HIA contract and other documents required by regulations are basically generic, so you don't have to worry about spending too much time on these ones during contract signing. Days before the contract signing, Simonds sent us the initial drawings as well as the colour selections after the gallery for review. We checked every details and send any issues (not as discussed during gallery) we found back to Simonds in which they were Ok to accommodate (as long as not structural change). Closer to contract signing, we checked the details over and over again and made some notes for those items that we're unsure or just require clarifications. As we go over to the details during contract signing, we just highlighted our notes to Simonds legal person. Anything they cannot answer, they said they'll just come back and if needed, they'll just create PCV (post contract variations) later on. So, we still ended up signing all docos during contract signing even if there are items that require clarifications. With all the clarifications we have and other drawing issues found during Simonds internal QA, there were about 6 PCVs created until the start of the construction. One of the issues we have was misunderstanding about the cooling system. The cost is different than what we we're told during gallery. My Simonds CRC (Customer Service Coordinator) was accommodating enough and they managed to clarify the issue with us, and we're happy how they handled it. Bottomline, don't pressure yourself too much. Just summarize any clarifications you need. Go through with them during contract signing, and ensure to have PCV if there are issues or items that require changes. My advise, just be polite to your CRC in all comms, that way they're happy to help you. Re: Simonds Prague with Modifications in Melbourne's North 15Jul 24, 2019 11:04 pm Re: Simonds Prague with Modifications in Melbourne's North 16Jul 25, 2019 8:29 am silentChaos Thanks for your advice above, sorry i didnt reply earlier but it was very helpful! and WOW!! things are moving quick! looks amazing so far! Re: Simonds Prague with Modifications in Melbourne's North 17Aug 19, 2019 11:14 pm Bricks were in placed. This was 2 weeks after the walling were up. The front pillars will still be covered with rendering. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Another 2 weeks after the bricks were up, floor tiles and kitchen just popped up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Simonds Prague with Modifications in Melbourne's North 18Oct 22, 2019 10:34 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sharing which might be one of my last updates. Here's the timeline so far: 23-Apr - Loan approval 01-May - Land settlement 14-Jun - Construction start 01-Jul - Base stage 04-Jul - Frame stage 01-Aug - Lockup stage 09-Sep - Fixing stage 10-Oct - PCI 22-Oct - PCS nearing handover soon... Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 22981 May I ask why you chose not to use GJ Gardiner? I'm actually meeting with one of the sales guys tomorrow for an appointment. Definitely not signing anything yet… 3 13406 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18341 |
