Browse Forums General Discussion Re: Polyurethane use 2May 04, 2019 2:57 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Polyurethane use 4May 04, 2019 6:38 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Please help the community by reporting Spam 5May 04, 2019 7:19 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Please help the community by reporting Spam 6May 04, 2019 7:44 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Please help the community by reporting Spam 7May 04, 2019 8:02 pm SaveH2O Joker chippy What every house needs. Ha ha ha ha,yes if Cancer is your wish. Do you guys know how to report spam? There are 3 dots at the bottom right hand corner. Clicking them will bring up a menu, just click on Report Post and a box will appear that allows you to report the post and the reason why. Re: Please help the community by reporting Spam 8May 04, 2019 11:24 pm It sounds like a programming issue. If you send a message to Homeone, I am sure that the issue will be discussed with the programmer. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Please help the community by reporting Spam 9May 17, 2019 3:55 pm Hi, This is Joshua the programmer for homeone. For tapatalk, to report a post on iOS you can tap the post and select 'Report' Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ On Android it should be similar, tap a post to select it and then pick the three dots at the top right of the screen (...) and select 'Report' Re: Please help the community by reporting Spam 10May 17, 2019 4:03 pm To add, already reported posts do not provide a [re]report option. I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 4448 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 3607 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 9682 |
