Browse Forums General Discussion 1 May 04, 2019 12:06 pm Polyurethane has multiple use in our life, if need polyurethane machine, contact me[img:232yk14a]https://forum.homeone.com.au/u/89280_1556935605.JPG[/img:232yk14a]
Re: Polyurethane use 2May 04, 2019 1:57 pm What every house needs. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Polyurethane use 4May 04, 2019 5:38 pm Joker chippy What every house needs. Ha ha ha ha,yes if Cancer is your wish. Do you guys know how to report spam? There are 3 dots at the bottom right hand corner. Clicking them will bring up a menu, just click on Report Post and a box will appear that allows you to report the post and the reason why. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Please help the community by reporting Spam 5May 04, 2019 6:19 pm Yes I know how to report spam and do so regularly. It often takes the mods hours if not days to remove it so was just having a laff. Thanks though. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Please help the community by reporting Spam 6May 04, 2019 6:44 pm chippy Yes I know how to report spam and do so regularly. It all helps. You have to shake your head (and maybe laugh) at some of the persistent ones, fake university degrees, fake passports and fake currency come up regularly. I love how Homeone changed this thread's title. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Please help the community by reporting Spam 7May 04, 2019 7:02 pm SaveH2O Joker chippy What every house needs. Ha ha ha ha,yes if Cancer is your wish. Do you guys know how to report spam? There are 3 dots at the bottom right hand corner. Clicking them will bring up a menu, just click on Report Post and a box will appear that allows you to report the post and the reason why. Re: Please help the community by reporting Spam 8May 04, 2019 10:24 pm It sounds like a programming issue. If you send a message to Homeone, I am sure that the issue will be discussed with the programmer. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Please help the community by reporting Spam 9May 17, 2019 2:55 pm Hi, This is Joshua the programmer for homeone. For tapatalk, to report a post on iOS you can tap the post and select 'Report' Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ On Android it should be similar, tap a post to select it and then pick the three dots at the top right of the screen (...) and select 'Report' Re: Please help the community by reporting Spam 10May 17, 2019 3:03 pm To add, already reported posts do not provide a [re]report option. I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5159 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7170 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12785 |
