Browse Forums Building A New House Re: No gas in new build 2May 02, 2019 3:05 pm Forgot to mention about the gas water heater. Would like to get an electric water heater as well but currently not sure how much the builders will cost & we may get it if the cost is not a lot higher. But still not sure about the supply charge if we don't use gas at all and there is a connection. Re: No gas in new build 3May 02, 2019 4:32 pm sarahbuilds Hi We are currently looking at builders and want a gas cooktop. Also don't intend to use a barbie as well. So would it be best that if we tell the builder to not get a gas connection at all. Will we have to pay for gas supply charge if there is a connection but we don't use it at all? Yes you will pay supply charge even if you don't use gas. Have you thought about heating as well? If no gas then you'll need reverse cycle ac/heater. More expensive up front. If you want to go fully electric, look at getting solar and battery, so you don't end up paying what you save on gas in electricity. Building the Votivo43 - viewtopic.php?f=31&t=88553 Building the Arden Votivo 43 Follow me here: https://forum.homeone.com.au/viewtopic.php?f=31&t=88553 4 10821 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3655 |
