Browse Forums Building A New House Re: Layout planning 22Apr 17, 2019 10:44 pm My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Layout planning 28Apr 22, 2019 9:18 pm I think your new plan looks much more well laid out that the initial plan. But a few points to consider: There isn't much pantry space in your kitchen of that size. What's the alcove on the opposite side of the kitchen backing the WIL used for? Perhaps put some kitchen pantry space and doors there? Your kitchen island is currently around 90cm deep. I'm assuming you're not going to use it as a breakfast bar and put bar stools on the other side, because if that's the plan you'll need to increase the depth a bit. You wardrobes are around 150-160cm wide and 45cm deep. I'd try to increase the width a bit (there's still a bit of space to the door) and increase the depth so that the sliding doors don't hit your clothes on the hangers as they open and close. And are you sure you'll need that "naughty corner" study nook in front of the WIL? My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Layout planning 29Apr 25, 2019 7:07 pm ben888 I think your new plan looks much more well laid out that the initial plan. But a few points to consider: There isn't much pantry space in your kitchen of that size. What's the alcove on the opposite side of the kitchen backing the WIL used for? Perhaps put some kitchen pantry space and doors there? Your kitchen island is currently around 90cm deep. I'm assuming you're not going to use it as a breakfast bar and put bar stools on the other side, because if that's the plan you'll need to increase the depth a bit. You wardrobes are around 150-160cm wide and 45cm deep. I'd try to increase the width a bit (there's still a bit of space to the door) and increase the depth so that the sliding doors don't hit your clothes on the hangers as they open and close. And are you sure you'll need that "naughty corner" study nook in front of the WIL? Hi Ben888, how does this new plan look? I got the builder modify the last one following some of your advice... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon 3 12441 I am not based in Victoria however i had a quick look into your question to understand what you were asking. The way I read the regulations, overshadowing relates to the… 1 2246 "is it exempt or do I need to get permission from council" Call your Council and ask them 1 1586 |
