Browse Forums DIY, Home Maintenance & Repair Re: Replacing porch support beams 5Apr 21, 2019 2:36 pm arcadelt Daina The top ends are fine. It’s just the base of the supports that are rotten due to exposure. Thanks for the fast response Sorry, but that photo shows me nothing as it is too dark. You cannot replace just the bottom of the post (well, you could, but it’s not advisable and the end result would be ugly). Please take another photo that clearly shows how the post is attached to the beam. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Replacing porch support beams 10Apr 21, 2019 7:52 pm Yup! So it’s quite overdue and supporting a roof overhang over the porch which isn’t ideal. I thought it may be a matter of hiring some supports while replacing the beams but my hubby seems to the the stirrups have a rod footing in the base of the beams which would make it impossible to replace. I’m clueless and thought I’d throw it out there for ideas and advice Re: Replacing porch support beams 11Apr 21, 2019 11:39 pm Daina Yup! So it’s quite overdue and supporting a roof overhang over the porch which isn’t ideal. I thought it may be a matter of hiring some supports while replacing the beams but my hubby seems to the the stirrups have a rod footing in the base of the beams which would make it impossible to replace. I’m clueless and thought I’d throw it out there for ideas and advice It’s not impossible. If you wanted to use the existing stirrups, you would have to prop up the beams, and even push them up sufficiently to raise the poles over and then down onto the rod. Of course, since the verandah ceiling is lined, you would need to remove the lining, but the plus is that there may be space up there so the beams do not need to be raised. You would also want to be sure that the lining is not asbestos given that it is all from the 60s. The alternative is to cut the stirrups at ground level and replace them with the more standard U-shaped ones that you can bolt into the concrete floor, and that have bolts through the bottom of the post. In that case, you might not need to remove the lining, but cut the posts so that the tops are just at the height of the ceiling. If you use slightly thicker posts, they would even cover over the hole in the lining. Re: Replacing porch support beams 12Apr 22, 2019 9:49 am arcadelt Daina Yup! So it’s quite overdue and supporting a roof overhang over the porch which isn’t ideal. I thought it may be a matter of hiring some supports while replacing the beams but my hubby seems to the the stirrups have a rod footing in the base of the beams which would make it impossible to replace. I’m clueless and thought I’d throw it out there for ideas and advice It’s not impossible. If you wanted to use the existing stirrups, you would have to prop up the beams, and even push them up sufficiently to raise the poles over and then down onto the rod. Of course, since the verandah ceiling is lined, you would need to remove the lining, but the plus is that there may be space up there so the beams do not need to be raised. You would also want to be sure that the lining is not asbestos given that it is all from the 60s. The alternative is to cut the stirrups at ground level and replace them with the more standard U-shaped ones that you can bolt into the concrete floor, and that have bolts through the bottom of the post. In that case, you might not need to remove the lining, but cut the posts so that the tops are just at the height of the ceiling. If you use slightly thicker posts, they would even cover over the hole in the lining. Thank you! I think we might go with the second option. I see the new u shaped stirrups come in different heights. We could potentially cut off the rotten ends and replace the old stirrups with raised ones. Likely to look odd but I dont want to mess with asbestos. I know it was in the roof when that was replaced and likely to be the lining of the porch. Re: Replacing porch support beams 13Apr 24, 2019 12:30 am Good advice from arcadelt If you replace posts you may consider Cypress pine or treated pine for new posts they are more durable Don't forget oil based timber primer to the bottom and sides of new timber Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog THanks , l got a licensed building inspector to look at the rust, he said its just surface rust and it would take many years to become a problem because the beams are so… 22 28450 if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush 4 7528 |
