Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 801Apr 12, 2019 1:40 pm Build thread: viewtopic.php?f=31&t=32574 Re: I work in flooring - do you have a flooring question? 802Apr 12, 2019 2:03 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 803Apr 12, 2019 2:18 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 807Apr 18, 2019 7:29 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 809Apr 18, 2019 7:40 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 810Apr 18, 2019 7:42 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 812Apr 18, 2019 7:45 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 813Apr 18, 2019 7:57 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 814Apr 18, 2019 8:04 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 816Apr 18, 2019 8:30 pm Buildingindoreen Michelle By the way... $65m2 is very cheap, not water proof and probably only 7mm, look into to that!! Thanks Michelle. Is $100m2 for Vinyl reasonable? I will ask them about a hybri as well. Where does that sit price-wise in comparison with the other two options? Yes, its close, not knowing what vinyl they are quoting you on?? You need to find that out also, which brand? Karndean do a locking clip which is around $110 installed, others are slightly cheaper. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 817Apr 18, 2019 8:31 pm Michelle Buildingindoreen Michelle By the way... $65m2 is very cheap, not water proof and probably only 7mm, look into to that!! Thanks Michelle. Is $100m2 for Vinyl reasonable? I will ask them about a hybri as well. Where does that sit price-wise in comparison with the other two options? Yes, its close, not knowing what vinyl they are quoting you on?? You need to find that out also, which brand? Karndean do a locking clip which is around $110 installed, others are slightly cheaper. Yes it's Karndean that they've quoted. I think I'll have to look into it more, it's sounding pretty great! Re: I work in flooring - do you have a flooring question? 818Apr 18, 2019 8:43 pm Getting a bit over loosing my posts here!! Go to a Choices flooring store, they will be able to give you all the info you need. In fact MOST flooring stores keep Karndean! De Novo Concepts - http://www.denovoconcepts.com online building advice Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 819Apr 18, 2019 8:46 pm Michelle Getting a bit over loosing my posts here!! Go to a Choices flooring store, they will be able to give you all the info you need. In fact MOST flooring stores keep Karndean! De Novo Concepts - http://www.denovoconcepts.com online building advice Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks so much Michelle, I will do that Re: I work in flooring - do you have a flooring question? 820Apr 23, 2019 3:42 pm Hi Michelle, The planting hybrids are advertised to be fade resistant but the korlok by karndean don't mention it at all. Between the karndean and proline rigid cores... What would you put down? Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39749 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10105 |
