Browse Forums General Discussion Re: Drainage issues - Can someone please help.... 2Apr 06, 2019 10:31 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Drainage issues - Can someone please help.... 3Apr 06, 2019 10:46 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage issues - Can someone please help.... 5Apr 07, 2019 1:24 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage issues - Can someone please help.... 7Apr 07, 2019 6:58 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage issues - Can someone please help.... 9Apr 10, 2019 4:25 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage issues - Can someone please help.... 12Apr 10, 2019 10:27 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage issues - Can someone please help.... 13Apr 11, 2019 9:16 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage issues - Can someone please help.... 15Apr 12, 2019 4:06 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage issues - Can someone please help.... 17Apr 15, 2019 11:13 pm An additional fact that you need to know to understand the system is that the friction loss expressed as equivalent pipe length of the pipe between the pit and the intersecting junction is about 46m. A 250 mm water level above the pipe's invert in the pit will provide a maximum flow rate of about 390 lpm provided that the intersecting water through the junction has good velocity and (I think) not act as a flow restriction that the current slow flow from dp 1, 2, 3 & 4 does. The real life pit to kerb figure will be less than this because of the flow restricting and volume reducing entrained air produced from jetting water in communication from dp5 and dp6 to the stormwater pipe (the same cause of the bubbling you have seen in the pit) and also from the additional intersecting water in the junction and the remaining pipe to kerb, the reason why achieving good stratified flow velocity from dp1, dp2 & dp3 will be vital. There will be some minor pipe slope between the junction and the kerb. There would be no air entrainment generated by the 32mm valve because it would operate under full flow conditions but fitting an air release valve further along the storm water pipe will need consideration. There are also a couple of other but similar variations to my initial suggestion. NOTE: The surface level at the junction is 200mm lower than at the pit but we don’t know what the pipe’s depth at the junction is. The plumber however has said that the cam showed ponding in the pipe and it would be expected that the pipe depth at the junction was not as deep as the pipe level in the pit. No allowance for any additional (unknown) pipe slope was made in the head/flow calculations but some minor additional head should be reasonably expected. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 6948 Hi there everyone i was hoping to get some details and some clarification on some potential defects that may have occurred our recent bathroom renovation. 1. There seems… 0 6968 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12280 |
