Steaming ahead, Magnus! Is that the Diplomat facade? We are between frame and brick and the parapets look more imposing and taller than I expected.
Browse Forums Building A New House Re: Building with Wisdom Homes 14505Apr 15, 2019 6:33 pm looks like rough small rocks/gravel and is done after the first course of bricks I believe. Did you specify Granitguard? do you have a date for when your bricklayers will start? Re: Building with Wisdom Homes 14506Apr 15, 2019 8:39 pm Manhattan52 looks like rough small rocks/gravel and is done after the first course of bricks I believe. Did you specify Granitguard? do you have a date for when your bricklayers will start? Yes it says “granite guard in lieu or standard” in our tender. So it is within the brick work? Thanks! No firm date, cement and sand are on site, inspection booked for tomorrow, SS wants to see report before proceeding. Re: Building with Wisdom Homes 14507Apr 15, 2019 8:46 pm becks81 Manhattan52 looks like rough small rocks/gravel and is done after the first course of bricks I believe. Did you specify Granitguard? do you have a date for when your bricklayers will start? Yes it says “granite guard in lieu or standard” in our tender. So it is within the brick work? Thanks! No firm date, cement and sand are on site, inspection booked for tomorrow, SS wants to see report before proceeding. Yes goes on the inward side of the bricks I believe. Hopefully you don’t have too much of a wait but better to address any frame issues now because no framework is perfect Re: Building with Wisdom Homes 14508Apr 16, 2019 10:00 am becks81 Manhattan52 looks like rough small rocks/gravel and is done after the first course of bricks I believe. Did you specify Granitguard? do you have a date for when your bricklayers will start? Yes it says “granite guard in lieu or standard” in our tender. So it is within the brick work? Thanks! No firm date, cement and sand are on site, inspection booked for tomorrow, SS wants to see report before proceeding. What they do is lay the first course of bricks and then Flick will put 75mm of crushed granite in the cavity, The termites cant get through Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 14509Apr 16, 2019 11:07 am With these crushed stone type physical termite systems we'll probably find that there is also a plastic strip laid into the brick courses designed to prevent termites tunnelling up inside the structure. The critical thing with these systems and their typical warranties is to recognise the requirement for yearly professional inspections and the retention of those inspections reports. Re: Building with Wisdom Homes 14511Apr 16, 2019 11:22 am Sorry for the heavy posting of late: Does anyone have a good checklist for the pre-lining inspection? Or any tips as to what to look for? I obviously want to be really thorough but also don't want to annoy our SS. Re: Building with Wisdom Homes 14512Apr 16, 2019 12:40 pm becks81 Granite guard: can anyone explain to me how this will look and when it goes in? We have frames up (as much as possible without scaffolding) and brickies due when possible, allowing for Easter. Hi becks81, SS literally just got off the phone with hubby about 2 mins ago for weekly update call... our bricks were delivered yesterday (there was a 2 week delay on Austral's part!). And the granitgard was being done as they speak! Our bricks won't be started on until after Easter break. Re: Building with Wisdom Homes 14513Apr 16, 2019 2:49 pm ASJ1981 becks81 Granite guard: can anyone explain to me how this will look and when it goes in? We have frames up (as much as possible without scaffolding) and brickies due when possible, allowing for Easter. Hi becks81, SS literally just got off the phone with hubby about 2 mins ago for weekly update call... our bricks were delivered yesterday (there was a 2 week delay on Austral's part!). And the granitgard was being done as they speak! Our bricks won't be started on until after Easter break. Austral are really slow at delivering at the moment. I should be getting mine tomorrow. race you to the finish Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 14514Apr 16, 2019 3:02 pm SejaeD Austral are really slow at delivering at the moment. I should be getting mine tomorrow. race you to the finish Hahaha sejaeD, apparently Austral can not keep up with the supply and demand SS had shown us an email from Austral Sales with the estimated delivery time of our brick and it was a 2 week wait! Austral gave us an option of another brick that was available sooner.... it ended up being a blessing in disguise because i was secretly second guessing our original brick choice (we drove around the estate and realised almost every house had the same brick!) And this would be partly due to the fact that our Estate developer wanted medium to dark face bricks . Anyway, needless to say, we drove down to Austral to check out the other brick and we liked it better! Re: Building with Wisdom Homes 14515Apr 16, 2019 3:22 pm ASJ1981 SejaeD Austral are really slow at delivering at the moment. I should be getting mine tomorrow. race you to the finish Hahaha sejaeD, apparently Austral can not keep up with the supply and demand SS had shown us an email from Austral Sales with the estimated delivery time of our brick and it was a 2 week wait! Austral gave us an option of another brick that was available sooner.... it ended up being a blessing in disguise because i was secretly second guessing our original brick choice (we drove around the estate and realised almost every house had the same brick!) And this would be partly due to the fact that our Estate developer wanted medium to dark face bricks . Anyway, needless to say, we drove down to Austral to check out the other brick and we liked it better! Its funny how these things work out! Glad you got a better choice. I am just using commons but its still a slow wait. I just realised that I might be ahead of you as my roof went on yesterday. Due to all my problems my build is going slight backwards Sunrise in West pymbleLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 14516Apr 16, 2019 3:24 pm Its not mandatory as with the chemical treatments which require new chemicals each year, but it's a good idea to still have flick come out each year and do a quick visual inspection. Mine is going in next week which is why I am all over this:) Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 14517Apr 16, 2019 3:33 pm ASJ1981 SejaeD Austral are really slow at delivering at the moment. I should be getting mine tomorrow. race you to the finish Hahaha sejaeD, apparently Austral can not keep up with the supply and demand SS had shown us an email from Austral Sales with the estimated delivery time of our brick and it was a 2 week wait! Austral gave us an option of another brick that was available sooner.... it ended up being a blessing in disguise because i was secretly second guessing our original brick choice (we drove around the estate and realised almost every house had the same brick!) And this would be partly due to the fact that our Estate developer wanted medium to dark face bricks . Anyway, needless to say, we drove down to Austral to check out the other brick and we liked it better! I just looked on your blog and I love your new bricks, but couldnt see the original ones either way your house is going to look amazing Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 14518Apr 16, 2019 4:18 pm ASJ1981 becks81 Granite guard: can anyone explain to me how this will look and when it goes in? We have frames up (as much as possible without scaffolding) and brickies due when possible, allowing for Easter. Hi becks81, SS literally just got off the phone with hubby about 2 mins ago for weekly update call... our bricks were delivered yesterday (there was a 2 week delay on Austral's part!). And the granitgard was being done as they speak! Our bricks won't be started on until after Easter break. That's why i haven't see your brick work start. We finished the first floor brick work and the roof tile! Wait for easter break to complete the second floor brick! Re: Building with Wisdom Homes 14519Apr 16, 2019 6:39 pm ASJ1981 SejaeD Austral are really slow at delivering at the moment. I should be getting mine tomorrow. race you to the finish Hahaha sejaeD, apparently Austral can not keep up with the supply and demand SS had shown us an email from Austral Sales with the estimated delivery time of our brick and it was a 2 week wait! Austral gave us an option of another brick that was available sooner.... it ended up being a blessing in disguise because i was secretly second guessing our original brick choice (we drove around the estate and realised almost every house had the same brick!) And this would be partly due to the fact that our Estate developer wanted medium to dark face bricks . Anyway, needless to say, we drove down to Austral to check out the other brick and we liked it better! Just saw your blog update. We have chosen Wilderness Design - Blackbutt as well and due to start bricks in about 4 weeks I am estimating. We may have to look for an alternative if the supply side issue continues. I always had on my wish list the Austral Metallix - Bronze but that was going to cost $13k extra. I wonder if we have to change, will they throw in a discount... Building Manhattan 44 Ens + Savannah Elite facade KDRB Tender Accepted 26/03/18; Contract signed 27/05/18; CDC submission 24/10/18; End Panel 13/02/2019; Slab 19/03/2019 Re: Building with Wisdom Homes 14520Apr 16, 2019 6:43 pm Stukip ASJ1981 SejaeD Austral are really slow at delivering at the moment. I should be getting mine tomorrow. race you to the finish Hahaha sejaeD, apparently Austral can not keep up with the supply and demand SS had shown us an email from Austral Sales with the estimated delivery time of our brick and it was a 2 week wait! Austral gave us an option of another brick that was available sooner.... it ended up being a blessing in disguise because i was secretly second guessing our original brick choice (we drove around the estate and realised almost every house had the same brick!) And this would be partly due to the fact that our Estate developer wanted medium to dark face bricks . Anyway, needless to say, we drove down to Austral to check out the other brick and we liked it better! Just saw your blog update. We have chosen Wilderness Design - Blackbutt as well and due to start bricks in about 4 weeks I am estimating. We may have to look for an alternative if the supply side issue continues. I always had on my wish list the Austral Metallix - Bronze but that was going to cost $13k extra. I wonder if we have to change, will they throw in a discount... stukip I used the Metallix Blackstone I think cost an extra $18k and they also had a slight delay but didn’t affect us as bricklayers were also delayed. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18466 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73474 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8240 |
