Browse Forums Building A New House Re: Conduits in single leaf brick wall 6Apr 12, 2019 10:25 am Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Conduits in single leaf brick wall 8Apr 12, 2019 6:10 pm When we went with Intelligent Home they had to check if our builder would allow the 50mm conduit that some Samsung TV's require for their HDMI cable. Their rep said they had to get approval. I have heard that some builders will force you to put a double leaf in the theatre room if you want to run a lot of cables in (friends of ours did it with their build). Re: Conduits in single leaf brick wall 9Apr 12, 2019 11:24 pm I am really struggling to come up with a scenario where HDMI cable needs to be ran through the wall instead of being put into just cool looking external conduit from media wall-based Apple TV or media player directly to the wall mounted TV. I would imagine Cat 6 needs to go through the wall though. But may be that's just me. Re: Conduits in single leaf brick wall 10Apr 13, 2019 12:26 am Andree chippy We have similar in our house (WA) so it shouldn't be a problem. As long as you don't want horizontal chases. The conduit for HDMI is quite large so if you are trying to run numerous conduits to feed them it will start to compromise wall integrity. Forg. In Perth we build double brick. All the internal walls are only single brick wide (double on external) so any electrical or plumbing needs to be cut (chased) into the bricks before the hard plaster is done over the top. It's the same as the electrical and plumbing rough in you do in stud walls except it's cut into the brick. Thanks. Apart from a double GPO, we have asked for two 32mm and a 25mm conduits centrally from 300 -1200AFL for the TV mounting, as well as four other 32mm conduits. (all vertical) They have said this is too much for a single leaf wall - even spreading over 3.8m Why do you need so many 32mm conduits? Your TV only needs one not two. What are the other 4 for? It seems unnecessary. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Hello All π We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8214 canβt tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4470 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7945 |
