Browse Forums Building A New House Re: Building near protected trees 3Apr 04, 2019 8:44 pm Melos MrChelseaFC Hi, After some advice. Based in Sydney - I'm wanting to use CDC for development. There are a number of protected trees on my site that I would like replaced and some kept. This will require me to put a request to council which I suspect will just get rejected. Therefore I'm considering compromising my design to accomodate the Trees and then go with CDC and get approval. My question is what happens if existing trees are then damaged in the future for some reason beyond my control. I.e. the roots are damaged by the builder.... I am liable to be sued...? Advice I am being told is that as long as you are not within 3m of the tree then you can build. If something happens then I am not liable. Thanks in advance. We request a tree removed from the nature strip. It was rejected and we have a $1.4 million bounty on the tree. If the tree dies during before or 18 months after the build we are liable. Council sux May I ask if this part of a new development application and if so did you need to submit a floor plan or just a stand alone request to remove a tree..? Re: Building near protected trees 4Apr 04, 2019 8:56 pm Melos We request a tree removed from the nature strip. It was rejected and we have a $1.4 million bounty on the tree. If the tree dies during before or 18 months after the build we are liable. Council sux 1.4M is a bit too much for a single tree. In the majority of countries the human life is valued much less. What tree is it I wonder? Re: Building near protected trees 6Apr 05, 2019 8:47 am MrChelseaFC Melos MrChelseaFC Hi, After some advice. Based in Sydney - I'm wanting to use CDC for development. There are a number of protected trees on my site that I would like replaced and some kept. This will require me to put a request to council which I suspect will just get rejected. Therefore I'm considering compromising my design to accomodate the Trees and then go with CDC and get approval. My question is what happens if existing trees are then damaged in the future for some reason beyond my control. I.e. the roots are damaged by the builder.... I am liable to be sued...? Advice I am being told is that as long as you are not within 3m of the tree then you can build. If something happens then I am not liable. Thanks in advance. We request a tree removed from the nature strip. It was rejected and we have a $1.4 million bounty on the tree. If the tree dies during before or 18 months after the build we are liable. Council sux May I ask if this part of a new development application and if so did you need to submit a floor plan or just a stand alone request to remove a tree..? Part of a kdr da, we have a tree in the middle of the nature strip and we wanted to move our drive way to the opposite side it was on. They said we couldn’t remove the tree but we could spend a small fortune on ground radar to see if the drive way would impact the roots. We did this and they then replaced their council tree guy who’s attitude was “everything by the book to the full extent, no compromise” tree and drive way stayed put. Re: Building near protected trees 7Apr 05, 2019 8:50 am cag57 Are you in Ku Ring Gai? They are crazy for trees. $1.4m is ridiculous and how could they possibly enforce a fine like that. I know right we would need to sell the house to cover the cost. The tree is completely lopsided because energy Aust cut the side out of it so it doesn’t touch the wires. Building near protected trees 8Apr 05, 2019 8:56 am alexp79 Melos We request a tree removed from the nature strip. It was rejected and we have a $1.4 million bounty on the tree. If the tree dies during before or 18 months after the build we are liable. Council sux 1.4M is a bit too much for a single tree. In the majority of countries the human life is valued much less. What tree is it I wonder? It’s an ugly brush box. Energy Aust come through every few years and cut the side off it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We wanted to move our driveway to the opposite side but it’s too close to the tree roots. That said I’m pretty sure our current drive way would also be too close to the roots based on their measurements. Re: Building near protected trees 9Apr 05, 2019 10:05 pm Any idea what is the procedure if you have a tree within your own property boundary and the driveway is being lifted by the tree. If I repair the driveway I will damage the tree roots and therefore the tree dies. Is one then able to plant new trees and have the troublesome tree removed.? Also if you go CDC how do you justify trees to be removed with council..? Lastly if I do go CDC is there a need to identify a Tree protection zone..? Re: Building near protected trees 10Apr 06, 2019 5:41 am For cdc have a look at clause 3.33 https://www.legislation.nsw.gov.au/#/vi ... /572/part3 You also need to check your local councils website as they should have clear guidelines for trees that aren’t covered by the cdc requirements A lot depends on which council you feeling to, where the tree is on your block, what species it is and how big it is. Good luck Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9479 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223633 |
