Browse Forums Building A New House Re: KDR - New Choice Homes Custom design - Perth, WA 65Apr 04, 2019 7:19 pm I wouldn't go for a dark roof, because they'll fade quite quickly in WA, but I guess it comes down to personal preference. They will be able to give you some ideas or maybe visit Houzz or Pinterest and see what works well together. NCH does have a designer you can visit, but she's quite expensive. Initially we were planning to see her, but we decided on our own anyway so we didn't even up seeing her. We had 27 LED's prior to pre-start and added a few more. They were good with advising where we should have switches in certain areas. We added quite a lot of extra power outlets, as 1 per room is never enough. Some of the rooms we added extra LED's to and we also added junction boxes in areas where we plan to put nicer light fittings later on, as then the main wiring is done and an electrician can add the lights later on. You should have the electrical costs list in the file? We only did the bare minimum with electrical, as we're getting an electrician in later to do a few extra bits anyway. Intelligent home was worthwhile, but beware it is quite expensive. I got them to do the basics (Cat 6 cabling for TV's and TV antenna points with a 4 way), which they were happy to do, but we're planning on doing extra stuff later on, like TV antenna etc. We upgraded quite a lot of stuff before we signed our contract, because we visited their pre-start office and looked at things we liked and added them up-front, like the integrated rangehood, gas on glass cooktop, upgraded aircon controller etc. We spent around an extra $12k at Pre-start, which was around $2k with intelligent home, $3k in electrical, $1,500 in tile upgrades (rectified, etc), $2k in cabinetry changes (even more drawers, finger grip in bathrooms, etc) and the rest was in plumbing (black taps, upgraded toilets, sinks, channel grate drains etc). Some things were quite affordable to change, others were eye-watering, like the Back to Wall freestanding bath ($1,800).... Re: KDR - New Choice Homes Custom design - Perth, WA 66Apr 04, 2019 7:48 pm I did hear about dark roof fading too, will keep checking out pinterest and houz etc for more ideas. Yes we did get the electrical costs list in the folder, will definitely be adding more power outlets too. We are not sure whether it is more ex to do the extra lightings from outside electrician, will have to google to find out more. We are pretty tight on budget hence trying not to spend too much on prestart but then it is so hard not to too. Thanks for your advices, it did give me some insight of what to expect and do for prestart Looking forward to seeing more updates of your build Re: KDR - New Choice Homes Custom design - Perth, WA 67Apr 04, 2019 8:10 pm April 4 - Plumbing and plaster
Plumbers were back today to fix a couple of bits..... Plumbing for our rainwater tank installed Rainwater plumbing cut in and installedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Rainwater pipe installed in Kitchen island benchLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front outside tap secured Front garden tap securedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Plasterers were on-site getting ready to start (sand and supplies delivered, metal corner beads finished, rooms swept and cleaned and feature wall taped up) Metal corner beads finishedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Plastering sand deliveredLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Plaster supplies deliveredLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Feature brick wall taped up 2Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Feature brick wall taped up 1Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR - New Choice Homes Custom design - Perth, WA 68Apr 05, 2019 8:14 pm April 5 - Plaster Day 1 Gas connected Gas meter installedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Plastering - Day 1 Kid's activity roomLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bed 2Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kid's Activity/Linen cupboardLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ BathroomLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Back hallwayLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Living room TV recessLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR - New Choice Homes Custom design - Perth, WA 69Apr 08, 2019 7:57 pm Hi thme, Can I check with you how many LED downlight do you have in your 3 minor bedroom? My 3 minor bedrooms are abt the same size as your house plan but am unsure whether one LED downlight is enough or to change to oyster light? Thank you! Re: KDR - New Choice Homes Custom design - Perth, WA 70Apr 08, 2019 8:13 pm zenith11 Hi thme, Can I check with you how many LED downlight do you have in your 3 minor bedroom? My 3 minor bedrooms are abt the same size as your house plan but am unsure whether one LED downlight is enough or to change to oyster light? Thank you! We only put 1 in each minor room. I'm not sure if that's enough or not. I guess time will tell.... They'll show you the different types of LED's in pre-start. From memory there's 3 different options, plus different colours and surrounds. Our master has 2 and an additional one in our robe. Re: KDR - New Choice Homes Custom design - Perth, WA 71Apr 08, 2019 8:20 pm April 8 - Plastering Day 2 They've finished the rear wing of the house today and moved onto the laundry. We bumped into one of the plasterer's on Saturday, he's booked to do the white set plaster starting the 24/04, so they've got this week and next to finish the grey float and do the ceilings and cornices. Bed 3Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bed 4Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ LaundryLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bathroom finishedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR - New Choice Homes Custom design - Perth, WA 72Apr 08, 2019 9:43 pm thme zenith11 Hi thme, Can I check with you how many LED downlight do you have in your 3 minor bedroom? My 3 minor bedrooms are abt the same size as your house plan but am unsure whether one LED downlight is enough or to change to oyster light? Thank you! We only put 1 in each minor room. I'm not sure if that's enough or not. I guess time will tell.... They'll show you the different types of LED's in pre-start. From memory there's 3 different options, plus different colours and surrounds. Our master has 2 and an additional one in our robe. Thanks thme for your reply again Re: KDR - New Choice Homes Custom design - Perth, WA 73Apr 10, 2019 8:34 pm April 10 - Plaster day 3 The guys weren't on-site yesterday, probably saw the forecast for 37C and decided to have a day off. They're making good progress, I think they should have the internals complete tomorrow and then have just the exterior plaster to do on the front and side. Powder roomLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Living room, looking out.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dining and livingLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen completeLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Theatre room completeLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR - New Choice Homes Custom design - Perth, WA 74Apr 11, 2019 8:50 pm April 11 - Internal plaster complete Just the external plaster on the front to complete. SculleryLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front hallwayLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front entryLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master bedroom 1Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master bedroom 2Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master robeLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ensuite toiletLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ensuite showerLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR - New Choice Homes Custom design - Perth, WA 75Apr 12, 2019 8:07 pm April 12 - Exterior Plaster They've got a small section to do above the portico lintel on the outside. You can see they put in a lot more effort with the finish on the outside to get it nice and smooth. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR - New Choice Homes Custom design - Perth, WA 78Apr 16, 2019 9:20 pm April 16 - Ceiling fixing day 1 The majority of the ceilings and cornices are complete. The guys were working until after 6.30pm and said they'll be finished tomorrow. Entry 34cLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Entry 34cLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Theatre recess 34cLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen bulkhead and scullery/laundry suspended ceiling 28cLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Alfresco 34cLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen bulkhead 28cLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Garage 31cLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Theatre recess 34cLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Portico 34cLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR - New Choice Homes Custom design - Perth, WA 80Apr 18, 2019 7:41 pm April 18 - White set plaster started, windows in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13301 ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 15086 |
