Browse Forums Flooring & Floor Covering 1 Apr 04, 2019 2:40 pm Hi, New here 👋🏼 I’m in the process of getting quotes to relevel our house. I have two quotes so far... One quote is $8800 to jack up the house and pack the stumps to level. PLUS $300 for additional stumps (which they suggested I required) or replacement of cracked stumps. PLUS $10 each for termite caps, 50 required. Second quote was $2600 to jack up house and pack to level. PLUS $150 per stump if any require replacing. No mention of extra stumps or termite caps. I’m unsure if $8800 is a total rip off or $2600 is a job not done properly? How can they be so different? I’m in the process of getting a third quote but am finding it hard to find anyone else to quote as we live on the Mornington Peninsula and it turns out that too far for people to come! I need a third quote because I am utterly confused by the first two... Can anyone shed some light on this for me? Re: Re leveling house ‘jack and pack’ 4Apr 04, 2019 9:36 pm aussieta 1st quote sounds more realistic but we dont know how many stumps need levelling without going under your house Thank you for your reply! I appreciate it. How can they accurately quote without going under the house then? It did actually shock me that neither company went under the house, the just waved a torch around from the trap door and came up with a figure... Re: Re leveling house ‘jack and pack’ 5Dec 16, 2019 11:32 pm Naez, have you done the jack and pack? I have just had mine done recently and have got a bit of experience to say it all depends on what is required. Doors jammed or crack bricks to be fixed? Re: Re leveling house ‘jack and pack’ 6Dec 17, 2019 5:54 am You could be treating symptom and not a cause. There is a reason why your house is out of level how do you know what it is? In a worst case scenario you could spend the money and your problem will return. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20678 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10051 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7035 |
