Browse Forums Building A New House 1 Apr 03, 2019 7:51 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Question about Bricklayer (Pictures attached) 5Apr 03, 2019 10:25 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Question about Bricklayer (Pictures attached) 6Apr 03, 2019 10:26 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Question about Bricklayer (Pictures attached) 12Apr 04, 2019 4:26 pm InvincibleInDN Hi All, Any know why this Foam strip is used between the joint of two wall? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can see this in multiple places where there is a corner joint. There is no Mortar/Cement used to connect them. If we remove the foam, we can see thru the hole. Will it be close later or left like that? Thanks They will use mastik or ableflex to fill the joint. Its an expansion joint so needs to be flexible and will look neat Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3372 Hi all, Been browsing project builders' website and saw Masterton with attached granny flat design Seeing bad reviews from masterton in this website/facebook, does… 0 18395 |
