Browse Forums Building A New House 1 Apr 03, 2019 7:51 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Question about Bricklayer (Pictures attached) 5Apr 03, 2019 10:25 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Question about Bricklayer (Pictures attached) 6Apr 03, 2019 10:26 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Question about Bricklayer (Pictures attached) 9Apr 03, 2019 11:47 am That's all OK, in terms of contemporary Australian building practice. It's an articulation joint at a wall offset where there is no lateral restraint requirement in the design. You don't want to think too much about why it is OK in terms of building practice. It's all to do with lighter-weight footings and foundations and a desire that movement in those elements not cause significant cracks in a building's visible masonry. There may be a lot more happening around that joint that you just won't see as a customer, things like flexible brick ties and slip-joint devices. Enjoy. Re: Question about Bricklayer (Pictures attached) 12Apr 04, 2019 4:26 pm ![]() Hi All, Any know why this Foam strip is used between the joint of two wall? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can see this in multiple places where there is a corner joint. There is no Mortar/Cement used to connect them. If we remove the foam, we can see thru the hole. Will it be close later or left like that? Thanks They will use mastik or ableflex to fill the joint. Its an expansion joint so needs to be flexible and will look neat Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 4438 Hi all, Been browsing project builders' website and saw Masterton with attached granny flat design Seeing bad reviews from masterton in this website/facebook, does… 0 19067 |
