Browse Forums Building A New House Re: Manhattan 21 heavily modified - Coral Homes Sunshine Coa 86Apr 03, 2019 8:54 am The only thing we spoke to the tiler about was making sure the tile lines matched up from inside to outside and from hallway into the wet area. We used the same tile through the whole house. Re: Manhattan 21 heavily modified - Coral Homes Sunshine Coa 87Apr 03, 2019 11:47 am bestspecials The only thing we spoke to the tiler about was making sure the tile lines matched up from inside to outside and from hallway into the wet area. We used the same tile through the whole house. Thanks. Your msg came just on time while we were discussing with tiler and was helpful.😊👍 Re: Manhattan 21 heavily modified - Coral Homes Sunshine Coa 88Apr 03, 2019 12:01 pm MrsAJ bestspecials The only thing we spoke to the tiler about was making sure the tile lines matched up from inside to outside and from hallway into the wet area. We used the same tile through the whole house. Thanks. Your msg came just on time while we were discussing with tiler and was helpful.😊👍 That's good. We are so happy with the outcome and it looks seamless. Re: Manhattan 21 heavily modified - Coral Homes Sunshine Coa 90Apr 11, 2019 8:50 pm I m not sure whether it is common but there r cut tiles on top as we extended our ceiling height and wanted to put full height tiling. Forgot to take pictures. Looks weird though. Then we were told adjustable shelves r standard as per their display homes but they havent done them yet. Asked our SS he is asking for tender or variation. Sent them the email from Coral homes saying it is standard. We also noticed there is gap between cabinet doors. It appears in few n rest all looks without any gap. 🙁🙆♀️ Re: Manhattan 21 heavily modified - Coral Homes Sunshine Coa 95Apr 18, 2019 6:11 am Entrance Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bathroom Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Butlers pantry Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ensuite shower Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Moon 😍 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Manhattan 21 heavily modified - Coral Homes Sunshine Coa 98Apr 19, 2019 6:44 am The front facade is looking good; especially liking the stacked stone. MrsAJ Any suggestions???? Should we buy black pier up down light or white/silver???? If you are referring to light for your front, black might look good with the other dark accents you have like the window frames. Re: Manhattan 21 heavily modified - Coral Homes Sunshine Coa 99Apr 19, 2019 7:11 am TiredHalo The front facade is looking good; especially liking the stacked stone. MrsAJ Any suggestions???? Should we buy black pier up down light or white/silver???? If you are referring to light for your front, black might look good with the other dark accents you have like the window frames. Thanks TiredHalo for your reply. 😊 Re: Manhattan 21 heavily modified - Coral Homes Sunshine Coa 100May 01, 2019 12:21 pm grommo79 it is a pretty fan but I have seen one that looks a bit cleaner. not sure if it is the same size, does any one know about this threesixty fan?? https://www.360in.com.au/ceiling-fans/spitfire/ Sorry I m not sure abt that fan and can't be of much help. At last minute we had to change our fans as we felt it would b big to have pendant n 56inch fan beside. I hope we made a good decision. Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13850 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4360 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74896 |
