Browse Forums Building A New House Re: Floor Plan Feedback 2Apr 02, 2019 8:13 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Floor Plan Feedback 10Apr 02, 2019 11:08 am justme15 Bebbsy Upstairs in the master bedroom en-suite I would consider making the toilet and shower niche a little wider, say to 950 or 1000mm, the room is large and can take it, and you get less soap etc on the shower walls which cuts down cleaning. (our showers are 1.0m wide and they are definitely easier to clean). 😏 Best of luck! Thanks, Bebbsy for chiming in. We started the process late November last year. It's still very much work in progress but we like the base. And that's why I've decided to seek additional feedback here hoping that others like yourself can add provide some value. So thank you again. Will definitely look at the two suggestions you've made. One of the other things we were thinking of doing was to bring the multipurpose room out so it runs flush with the other walls. Currently, it's set in. I also like the sound of easy cleaning Lol I was going to suggest that too...aligning the wall with the others, would give you more space in the multi purpose room, but had thought you might have had a reason for insetting it. Re: Floor Plan Feedback 12Apr 02, 2019 11:49 am BR1 downstairs - door that leads right off entry hall. Perhaps consider opening it the other way to block line of sight into the room and allow for more privacy. Re: Floor Plan Feedback 15Apr 02, 2019 12:51 pm gogo65 My only suggestion and it seems you have the width, is to make both downstairs equites run lengthways (i.e. both long and skinny with a window each). Something like this, I’d prefer the toilet under the window, gives you a large shower, you could do a walk in and a large vanity, but more important fresh air! Re: Floor Plan Feedback 16Apr 02, 2019 9:23 pm gogo65 Something like this, I’d prefer the toilet under the window, gives you a large shower, you could do a walk in and a large vanity, but more important fresh air! Thanks for that and taking the time to illustrate what you mean. It certainly helps and worth us looking into. Thanks again! Re: Floor Plan Feedback 18Apr 03, 2019 6:02 pm On orientation it seems to work quite well but I would look to reduce the amount of glass facing west on the ground floor. It will keep the living area much cooler and you are only losing a view of a fence. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Floor Plan Feedback 20Apr 03, 2019 6:16 pm bashworth On orientation it seems to work quite well but I would look to reduce the amount of glass facing west on the ground floor. It will keep the living area much cooler and you are only losing a view of a fence. Noted! Thank you. Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have… 4 12507 6 55354 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17286 |
