Browse Forums Building A New House Re: Custom Home v Project Home 5Mar 25, 2019 8:36 am Yeah, look we had a similar decision to make, except we went the other way around. We wanted to at least cost a custom build, because we wanted a design that incorporated appropriate shading, encouraged breezes, etc. When it came out around $1.2m with the only feature we couldn't get with a project builder being solar hydronic under-floor heating, we started looking at instead modifying project home designs. By the time the house was done, without landscaping it came out about the same cost as you're looking at, eshan. It's probably not quite right to extrapolate & say an equivalent custom build will therefore cost you $1.2m, but it's certainly true that it could easily cost you $1.2m. Re: Custom Home v Project Home 6Mar 25, 2019 6:24 pm Did a full custom home build,using project manager,home 48 squares,includes 2pac,3merbau decks, massive double sided stone entrance,top range German appliances,gas log stove,6star heating,air con,4step cornices throughout home,200mm skirtings,2.7 ceilings,40 metres of engineered retaining peaking at 2 metres high and rendered,40,000bricks used and home half rendered,solar, several skylights, cost 620,000,so saved anywhere from 200-300 000,point is volume boys can't do high end custom home especially if it has some shape ,has volume generally do more boxy houses dressed up, there are many ways to do a home. Re: Custom Home v Project Home 7Mar 26, 2019 1:28 pm ![]() Absolutely not. Custom builders build the house. 50k for a pool seems way to small, once you include pool fence etc and 20k for landscaping wouldn’t include driveway refining walls. Don’t forget you’ll probably still add more to your tender for electrical tile kitchen etc. Driveway and retaining walls are included with the builder. So 20k for rest should be ok. 50k for pool may be a small pool but think thats all we can afford at the moment. Re: Custom Home v Project Home 8Mar 26, 2019 1:29 pm ![]() Yeah, look we had a similar decision to make, except we went the other way around. We wanted to at least cost a custom build, because we wanted a design that incorporated appropriate shading, encouraged breezes, etc. When it came out around $1.2m with the only feature we couldn't get with a project builder being solar hydronic under-floor heating, we started looking at instead modifying project home designs. By the time the house was done, without landscaping it came out about the same cost as you're looking at, eshan. It's probably not quite right to extrapolate & say an equivalent custom build will therefore cost you $1.2m, but it's certainly true that it could easily cost you $1.2m. We have tried doing the same. Modified an existing home plan to suit our needs. Looks like custom build is not affordable at this point. who did you build with? Re: Custom Home v Project Home 9Mar 26, 2019 1:32 pm ![]() Did a full custom home build,using project manager,home 48 squares,includes 2pac,3merbau decks, massive double sided stone entrance,top range German appliances,gas log stove,6star heating,air con,4step cornices throughout home,200mm skirtings,2.7 ceilings,40 metres of engineered retaining peaking at 2 metres high and rendered,40,000bricks used and home half rendered,solar, several skylights, cost 620,000,so saved anywhere from 200-300 000,point is volume boys can't do high end custom home especially if it has some shape ,has volume generally do more boxy houses dressed up, there are many ways to do a home. Which custom builder dis you build with? Re: Custom Home v Project Home 10Mar 26, 2019 4:12 pm ![]() We have tried doing the same. Modified an existing home plan to suit our needs. Looks like custom build is not affordable at this point. who did you build with? Unfortunately this doesn't help you; a mob named Alkira Homes who were bought by (and I'm not 100% sure this is correct) one of the Rawson brothers & now only does house+land packages under a different company name. The finishes etc they had by default were pretty akin to what Rawson & Eden Brae were pushing. Re: Custom Home v Project Home 11Apr 24, 2019 7:07 pm As mentioned above it really does depend on the quality of finishes you want Cookie cutter home builders (Volume Builders) tend to get good pricing for their materials due to economies of scale, and they also get much better pricing from their trades for ongoing work. The issue is usually they stipulate the prices for their trades! So the trades generally look at getting things done faster in order to make the right money I used to work for a few volume builders in Brisbane that paid a decent SQM rate - higher than most. My partner and i could build a 2 storey 400sqm home from slab to roof in 10 days, including straightening walls, studs etc. Problem was that sqm rate made us $20 per hour working 10 hour days. The only way to increase the hrly rate was to build even quicker - dont straighten walls, dont straighten studs etc etc. It would all still meet code but was not ideal which is why I went custom. Haven't seen many volume builders at the Master Builders Awards ceremonies Re: Custom Home v Project Home 12Apr 24, 2019 7:12 pm ![]() ![]() Did a full custom home build,using project manager,home 48 squares,includes 2pac,3merbau decks, massive double sided stone entrance,top range German appliances,gas log stove,6star heating,air con,4step cornices throughout home,200mm skirtings,2.7 ceilings,40 metres of engineered retaining peaking at 2 metres high and rendered,40,000bricks used and home half rendered,solar, several skylights, cost 620,000,so saved anywhere from 200-300 000,point is volume boys can't do high end custom home especially if it has some shape ,has volume generally do more boxy houses dressed up, there are many ways to do a home. Which custom builder dis you build with? Re: Custom Home v Project Home 13Aug 10, 2020 11:53 pm Does Access homes Australia still exist? They were formally known as Alkira homes & had display homes at Kellyville Homeworld.. Cannot find any info on Access Homes Australia now. Does anyone know new contact details for Acchess Homes Australia. Built with Alkira 6 years ago. Re: Custom Home v Project Home 15Nov 18, 2020 3:01 am ![]() As mentioned above it really does depend on the quality of finishes you want Cookie cutter home builders (Volume Builders) tend to get good pricing for their materials due to economies of scale, and they also get much better pricing from their trades for ongoing work. The issue is usually they stipulate the prices for their trades! So the trades generally look at getting things done faster in order to make the right money I used to work for a few volume builders in Brisbane that paid a decent SQM rate - higher than most. My partner and i could build a 2 storey 400sqm home from slab to roof in 10 days, including straightening walls, studs etc. Problem was that sqm rate made us $20 per hour working 10 hour days. The only way to increase the hrly rate was to build even quicker - dont straighten walls, dont straighten studs etc etc. It would all still meet code but was not ideal which is why I went custom. Haven't seen many volume builders at the Master Builders Awards ceremonies What about California? It's an expensive area too, man I went out to these guys https://www.constructelements.com/ and decided to build on my own. What do you say, bad idea? Could anything go wrong with companies like this? Unfortunately that's what happens, make the rooms a bit bigger, add another garage and whola (Like magic) the prices go up a further $100K (disproportionately) ..and you… 5 1519 ![]() you need to do your research, above all else, need to feel comfortable and get everything in writing 3 2004 Hi all, We did a full renovation on our first home in England (non-structural) and bits and pieces in Australia to make some cosmetic changes in Australia using… 0 1309 |
