Browse Forums Building A New House Re: Building the Simonds Cleland 233 in SA 37Mar 21, 2019 4:44 pm darb74 Looking good. Seeing as you are able to get to the site easily, I would ask the builder for both the slab and plumbing set-out plans. This way you can do a basic check of things like the engineering specs for beam depth and widths etc. Also allows you to pick out any obvious service pipe location issues before they pour. Looks like all your horizontal pipes have been lagged, just make sure before the pour all the termite protection is applied to all pipe penetrations. My approach is to take heaps of photos, ask questions if something doesn't look correct. New houses are big investments and end of the day we as owners need to take an active interest in the whole building process. Looks like you are already doing that, so you should be fine I'd reckon. Thanks for the tips been taking plenty of pics etc and a vid following the pipes for future references too , also got all that data 👏 hopefully they have done the mesh and plastic I’ll head out there tonight for a looksy luckily Kaylie does underfloor inspections etc at work for the council Re: Building the Simonds Cleland 233 in SA 38Mar 24, 2019 7:02 pm Now that we are at the construction stage (slab being poured tomorrow 😁) I think it’s now safe to share our final house plan and elevations as I don’t think we will be making anymore changes 🤔 Although there’s a couple we would like to change like a cavity slider to the WIR and maybe raise the internal doors to upgraded higher ones (too late now and not really worth it) but overall we are extremely happy with everything for our first house and build 😍 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110793 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11127 |
