Browse Forums Building A New House Re: Need feedback on our floor plan 4Mar 20, 2019 9:23 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Need feedback on our floor plan 7Mar 20, 2019 10:06 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Need feedback on our floor plan 8Mar 20, 2019 10:11 pm bashworth I would be removing that west facing window in the master bedroom and make the north facing one bigger otherwise the room will overheat badly in the summer. The east facing window in the granny flat could also be dispensed with in favour of increasing the North facing window, In summer the room will heat up fast in the morning but in winter there won't be any benefit......and it will only give a view of the fence. The guest room and Bed 2 in the main house are also going to get very hot in summer. Thank you for your insight. Will be speaking to my wife about this tomorrow and will try to make changes. Appreciate it! Do you think the size of the house is around 337 sqm? Re: Need feedback on our floor plan 9Mar 20, 2019 10:12 pm TimBone gillybean Plan looks great. Only thing I’d change would be to maybe move the internal garage door 90 degrees onto the wall of the passage that leads to the ground floor powder room. That way you keep that entrance wall nice and “clean”. Size wise the measurements look like they are bang on the 337.4 m2. You have about 112 m2 upstairs and the ground floor looks roughly double that size. Thanks for this! Always good to have a new set of eyes. I would most likely follow your suggestion. You can't change the position of the door. The FL is 4 courses higher where the powder room is. The steps from the garage will end up to large and will eat up your garage space. It's not a large garage anyway. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Need feedback on our floor plan 10Mar 20, 2019 10:15 pm chippy TimBone gillybean Plan looks great. Only thing I’d change would be to maybe move the internal garage door 90 degrees onto the wall of the passage that leads to the ground floor powder room. That way you keep that entrance wall nice and “clean”. Size wise the measurements look like they are bang on the 337.4 m2. You have about 112 m2 upstairs and the ground floor looks roughly double that size. Thanks for this! Always good to have a new set of eyes. I would most likely follow your suggestion. You can't change the position of the door. The FL is 4 courses higher where the powder room is. The steps from the garage will end up to large and will eat up your garage space. It's not a large garage anyway. Thanks for this. So where the door is would be the best place where it should be? What do you think about our floor plan? Sorry if I ask too much. Thanks. Re: Need feedback on our floor plan 11Mar 20, 2019 10:36 pm Do the downstairs powder room, flat bathroom and laundry not have windows? Is it a requirement? Even if not, could you put windows/skylights in, it would make those rooms more pleasant to be in and help with ventilation. Re: Need feedback on our floor plan 12Mar 20, 2019 10:36 pm I agree with Bashworth RE the windows. Wherever possible maximize your north aspect. Personally I don't like the position of the powder room for the main house. If someone is staying in the guest room you have to walk through the public area of the house to access the shower. You've also had to introduce that passage way to hide the powder room door which just wastes space. Plus the window for the powder room is right next to the porch for the granny flat. It's a difficult one to change without some major redrawing but I'd be trying to get it next to the guest room, possibly semi-ensuited. The area at the front of the house with the void over seems to be a waste of space. Not sure what you plan doing with it but I can't see it being of much use. Maybe try to pick up space here by orienting the steps into it so you can move the guest room along and get the powder room over that side. Plans are very personal, so the way me and my family live and what's important to us may be very different to you, so always difficult to give advice on another person's plans. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Need feedback on our floor plan 14Mar 21, 2019 12:26 am North facing alfrescos will be shading away northern winter sun, so I would strongly consider making them with retractable roof design. Meals area will be always dark, while kitchen will be always overheated during summer (unless you put proper shading or glazing in place). See below. This powder room facing wall is taking space from the meals area while not providing much of privacy. It makes sense to keep a small WC over there, but the rest of the space is a good place for your Media room, while your Family and Meals area better to be moved to your current Media and Family areas respectively (Meals is just opposite the kitchen and family further to the north). Your huge northern window doesn't make any sense in the media room, but perfect for your Family room. Instead of dark Meals area now you are getting a lot of light from the family area and then you can have a small east facing windows for your media which is totally okay if it stays darker. Then reduce a bit the width of your WIP area, extend your existing laundry into that space and then add a small en suite to your guest bedroom. I would also swap shower and bath in the upstairs bath, as I won't be enjoying much sleeping Bedroom 3 when someone is showering behind my bad. Remove west facing window in Master Bedroom and extend North facing window instead. This bedroom is relatively small, so one big window will work out very well. You can actually even put a nice covered balcony with glass sliding door over there, so you your bedroom is well shaded off during summer (alternatively, consider longer eaves). Bedroom 2 and Guest room west facing windows are major concern, reduce glazing area and provide some strong protection from the western sun (tinted or Low E windows + heavy blinds/curtains/shutters). Otherwise, it will be extremely uncomfortable to sleep in those. The same applies to your Sitting area too. It always makes sense to have a window or two in the garage Just my 2 cents. Re: Need feedback on our floor plan 15Mar 21, 2019 5:54 am Can't believe I could get this much feedback and support since I posted this last night. Appreciate your perspective. Another concern we have is if the total size of the house is really 337.4 sqm. We just want to know if they measured it correctly. Re: Need feedback on our floor plan 16Mar 21, 2019 8:56 am I think your plan works well. I would pull the door to the downstairs bathroom into the hallway. That way when you open the door it doesn't impact the room at all and will have more space. It will make it feel bigger. I would change the granny flat doors to the bathroom and laundry to cavity sliders and that way you create more space as well. Re: Need feedback on our floor plan 17Mar 21, 2019 9:20 am TimBone Can't believe I could get this much feedback and support since I posted this last night. Appreciate your perspective. Another concern we have is if the total size of the house is really 337.4 sqm. We just want to know if they measured it correctly. Without the exact measurements on the plan for every space, we can only give a 'looks so' based on what measurements are there. Re: Need feedback on our floor plan 18Mar 21, 2019 10:19 am TimBone Can't believe I could get this much feedback and support since I posted this last night. Appreciate your perspective. Another concern we have is if the total size of the house is really 337.4 sqm. We just want to know if they measured it correctly. Just based on the numbers in the plan, 20.030x7.990 + 14.870x7.990 + 60 (assuming this for gflat) =338.85 Seems about right? Re: Need feedback on our floor plan 19Mar 21, 2019 1:00 pm Size can vary depending on how it is worked out.....see the following link to see what the differences are: http://anewhouse.com.au/2012/01/comparing-house-sizes/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. 6 55610 Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have… 4 12604 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17432 |
