Browse Forums Building A New House Re: Hebel Or Bricks 4Jun 14, 2018 2:48 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hebel Or Bricks 6Mar 20, 2019 9:00 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hebel Or Bricks 9Mar 20, 2019 9:37 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hebel Or Bricks 13Mar 20, 2019 10:22 am rameshbhai Also, saying that my project manager said using hebel will save a lot of money in scaffolding compare to bricks. But wondering does scaffolding cost too much money and if yes how much $5k, $10k $20k. Any rough estimate. It is a 23sq house on inclined land. Hebel walls come up quicker than Brick....thus requiring scaffolding rental for less time. Re: Hebel Or Bricks 14Mar 20, 2019 10:34 am Scaffolding Costs are less than $500/wk and the reason the council wants to know the building materials is they don't want it to Burn Down or Structurally Collapse Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hebel Or Bricks 15Mar 20, 2019 10:42 am Thanks for your suggestions. So, now I have to decide if I go with hebel or brick? is hebel as durable as brick? Re: Hebel Or Bricks 16Mar 20, 2019 10:51 am rameshbhai Welcome to the forum Try Googling Is hebel as durable as brick? & Check out Material Mechanical properties,etc For project specific Data and Proofs use Building Information Modelling (BIM) on ur project eg. Slab and Form work Costs Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hebel Or Bricks 17Mar 20, 2019 10:57 am Also consider your finish. Render is like paint and will look old and worn after a while and need repainting if you wish Brick will pretty much look the same forever Re: Hebel Or Bricks 18Mar 20, 2019 11:06 am I read other forums and some say the repainting require after 7 to 8 years and that too depends on the area you live. wondering if it will cost too much to use bricks or hebel panels on an inclined land. The land is 2 meters inclined. Re: Hebel Or Bricks 19Mar 20, 2019 12:57 pm A carpenter can put up Hebel in a few days whereas bricking may take a month or more and requires brickies. You don’t actually do any maintenance to the actual Hebel, Hebel is reinforced aerated concrete panels, the maintenance comes because the Hebel is rendered and painted. Any painted surface will require ongoing maintenance especially surfaces facing West. The render can crack especially if the renderer is a cowboy type and doesn’t do it properly, but a read through this forum will show the issues with brickies doing horrible brick work jobs also. Bricks virtually zero maintenance but will always be the same unless you render over and paint. Hebel whilst requiring ongoing maintenance always give you the opportunity to completely change the look of your house. From my research Hebel also comes out better for its insulation properties and sound deadening compared to brick. Re: Hebel Or Bricks 20Mar 20, 2019 2:15 pm All else being equal, Hebel should mean better insulation & quicker installation & an ability to patch over the final finish, with face bricks once it's done it's done. Additionally, does Hebel require acid washing like bricks do? Because the builder is less likely to munt the finish on your aluminium windows if that acid washing isn't needed (I sadly speak from experience). We'd probably have gone with Hebel and put up with the 10-yearly need to re-render (or at least paint), if the builder had been set-up to use Hebel. They offered it, but because it was a rare exception for them, it was considerably more expensive so we went with the low-maintenance face-brick instead. In a way I was glad, because rendered houses look very 1997 to me, and Sydney probably doesn't "need" the extra insulation (ie. it'd have made little difference to me). But … if the Hebel doesn't need acid washing, then in conditional hindsight I wish we'd paid the extra for the Hebel! I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5938 1 6698 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6351 |
