Browse Forums General Discussion Re: Stormwater Pit and plumbing pipes. 2Mar 17, 2019 9:21 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater Pit and plumbing pipes. 4Mar 17, 2019 11:06 am ORGs are on drain pipes, not stormwater pipes. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater Pit and plumbing pipes. 7Mar 17, 2019 1:12 pm wagga123 above the stormwater drain Are you referring to a storm water pipe or a surface stormwater drain? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater Pit and plumbing pipes. 9Mar 17, 2019 5:47 pm Reading it again, it doesn't make sense. Situation: 1. Stormwater Pit in backyard, 2. About half a meter out from the pit, there is a garden planting area, 3. Water tap to be installed with at least 100 mm separation in this garden area (above the underground stormwater drain pipe that the pit is connected to), 4. Can an ORG be installed in the same area as the water tap? Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10816 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10469 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8467 |
