Browse Forums Building A New House 1 Feb 27, 2019 11:40 pm Hi guys, I need advice on what to do with my block of land in Riverstone nsw . I owned ( no loan) a block of land 550sqm. I am currently renting @$2000 a month and desperately want to build house . I want to build something on it within 100k range. What will council allow/ what can I build for 100k. Can I utilize the vacant block to generate any income ? Please guide me Thanks in advance Advice needed on Blick of land 2Feb 28, 2019 5:49 am am2010 Hi guys, I need advice on what to do with my block of land in Riverstone nsw . I owned ( no loan) a block of land 550sqm. I am currently renting @$2000 a month and desperately want to build house . I want to build something on it within 100k range. What will council allow/ what can I build for 100k. Can I utilize the vacant block to generate any income ? Please guide me Thanks in advance What did you have in mind for $100k? These guys suggest you could get something starting at $73k but it might be more like a granny flat https://www.baahouse.com.au/designs Re: Advice needed on Blick of land 3Feb 28, 2019 1:36 pm May be better wait a bit and save some more money as the build prices a likely to go down. Not the best time to build in NSW. Odds are high that you will be able to afford much better house for your money by the end of 2019. Also, consider building to the temporary occupancy certificate stage and then slowly finishing off when you are already living in the place. Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18154 |
