Browse Forums Heating, Cooling & Insulation Re: Whirly bird or solar roof ventilation 6Mar 01, 2019 12:50 pm I'm looking into using a solar vent as well, i think they are more reliable than a whirly bird since you could choose to turn them on and off depending on roof temperature. Take a look at this blog which does a comparisons of the products available on the market https://www.roofventilationblog.com.au/ ... -2018/815/ Re: Whirly bird or solar roof ventilation 7Mar 07, 2019 10:53 pm We have just purchased an Edmonds AiroMatic that our builder will be installing probably next week, along with our roof! It is reportedly worth around 6 standard whirly birds in terms of air movement. It uses a standard 240v plug and has built in temp & humidity sensors. Will show some pics once it’s up and going. --------------------------------------------------------------------- Check our Homeone build blog here Re: Whirly bird or solar roof ventilation 8Mar 07, 2019 11:48 pm Althom I take it you need eave vents for the fan to be able to draw in outside air? What area of vent for one fan? Interesting that there's no answer to this question on here or directly via the suppliers website. Inlet vent area will be critical to the performance of the fan and yet there's no info available????? Re: Whirly bird or solar roof ventilation 9Mar 30, 2019 7:17 pm I have a full length ridge vent. I used the type you shingle over. They are near invisible. I had earlier put in a power gable vent. Ever since I put a new roof on and cleaned up the soffit vents, I have never heard it run. Re: Whirly bird or solar roof ventilation 10Jan 08, 2020 6:00 am I had an extraction fan (non solar) in my old house and air was the best $400 I spent. I had the thermostat set to 28°. Whirly birds for me are counter productive as they work all year round. Hot air rises and shoot out those vents. In my opinion that’s the last thing I want in winter. I regularly drive past homes on cold days and see them spinning away on people’s roofs. I bet they probably have their air con going to warm the house. Why expel valuable free warm air in your roof when it could be there warming your home. Just my opinion. Cheers Brickface Re: Whirly bird or solar roof ventilation 13Feb 15, 2020 3:54 pm kinigo270 Is there any way to prevent smoke from outside to come into the house on these units? Just my opinion Refer this https://www.solarking.net.au/product/solar-roof-vent Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7748 I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6693 |
