Browse Forums Building A New House Re: Starting our KDR journey Metricon Glendale 50 148Feb 18, 2019 3:36 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Starting our KDR journey Metricon Glendale 50 152Feb 18, 2019 5:00 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Starting our KDR journey Metricon Glendale 50 153Feb 18, 2019 10:15 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Starting our KDR journey Metricon Glendale 50 155Feb 20, 2019 10:49 pm Drew01 excited_builders Drew01 The tiles are unlikely to have a wax on them... It's more likely to be grout that hasn't been cleaned off properly. You can use a phosphoric acid cleaner available from Beaumont Tiles (make sure they know what tiles you have before using it) or get Metricon back to clean it again. Try spray and wipe or a citrus cleaner on a small section with paper towel and see what comes off https://r.tapatalk.com/shareLink?url=ht ... are_type=t Once you get handed over to your service person, they are actually pretty responsive. In our case, our current (second) maintenance lady is better than or BSC, and most likely our SS as well.... https://r.tapatalk.com/shareLink?url=ht ... are_type=t Re: Starting our KDR journey Metricon Glendale 50 156Feb 22, 2019 9:50 am We had things seen to before our 90 days was up. Aircon (twice), power points, front door lock and our hot water service. We've also got some rubber stuff on our bathroom tiles that I havent been able to shift. Leaving it for them now, far too pregnant to be dealing with their mess. Re: Starting our KDR journey Metricon Glendale 50 157Feb 25, 2019 6:12 pm blackcat20 We had things seen to before our 90 days was up. Aircon (twice), power points, front door lock and our hot water service. We've also got some rubber stuff on our bathroom tiles that I havent been able to shift. Leaving it for them now, far too pregnant to be dealing with their mess. https://r.tapatalk.com/shareLink?url=ht ... are_type=t Re: Starting our KDR journey Metricon Glendale 50 158Feb 25, 2019 6:39 pm excited_builders blackcat20 We had things seen to before our 90 days was up. Aircon (twice), power points, front door lock and our hot water service. We've also got some rubber stuff on our bathroom tiles that I havent been able to shift. Leaving it for them now, far too pregnant to be dealing with their mess. Ok thanks for letting us know. We have put the front door on the list since it slams shut instead of closing gradually. Does anyone have a video of their front door closing specially if you have a pivot door? https://r.tapatalk.com/shareLink?url=ht ... are_type=t You should be able to adjust the door yourself, it's like 5 min job. Depending on the brand of your door, most should have 2 adjustable valves. One for door speed, and one for latching speed. Easily adjusted normally with a flat head or allen key. Re: Starting our KDR journey Metricon Glendale 50 159Feb 26, 2019 12:28 pm dulie excited_builders blackcat20 We had things seen to before our 90 days was up. Aircon (twice), power points, front door lock and our hot water service. We've also got some rubber stuff on our bathroom tiles that I havent been able to shift. Leaving it for them now, far too pregnant to be dealing with their mess. Ok thanks for letting us know. We have put the front door on the list since it slams shut instead of closing gradually. Does anyone have a video of their front door closing specially if you have a pivot door? https://r.tapatalk.com/shareLink?url=ht ... are_type=t You should be able to adjust the door yourself, it's like 5 min job. Depending on the brand of your door, most should have 2 adjustable valves. One for door speed, and one for latching speed. Easily adjusted normally with a flat head or allen key. https://r.tapatalk.com/shareLink?url=ht ... are_type=t Re: Starting our KDR journey Metricon Glendale 50 160Feb 28, 2019 6:59 am Finally got my phone lead in and Nbn PCD box on the same day. After a lot of dramas, with the wrong technician coming first, the overhead telephone contracting company sent instead of underground etc. Yesterday the underground phone lead in contractor came and installed my phone line outside only from the pit through Ms conduit to the side of my meter box. Then the NBN person came and pushed the cable through that same conduit to the side of my wall. However on pushing that cable and phone line with the drawstring he found that the blank plate in the garage was 1 meter below the end of the conduit that ran against the garage wall. So advice for all before your plaster boards go up and if you have taken Nbn tske a picture of where the conduit ends till on the garage wall. As the electrician that put the plate just put it anywhere on the garage wall and he comes to fix his stuff after the walls are up so someone made a mistake in informing him the location of the blank plate that needed to be fixed!!! Anyway the NBN guy was super helpful and told hubby to get a 30 meter cat6 cable and he waited while he went to buy it and then pulled it through with some kind of wire roll weight. The alternative was cutting a hole through the wall where the conduit ended and place another plate there. Now have to wait for the modem tech and phone tech to come and do the actual connections inside to connect our phone and internet. https://r.tapatalk.com/shareLink?url=ht ... are_type=t Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7223 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37160 |
