Request it from your SS at electrical rough in stage. They will probably do it as it’s not adding something new just slightly moving it
Browse Forums Building A New House Re: Building with Wisdom Homes 14164Feb 16, 2019 3:06 pm [quote="Kvav27"]Hi All, We are very close to PCI since December 15th, 2018. My SS has been very good in giving updates every weekend. But since after the holidays when only a couple of things look to be remaining, i see weeks of no activity, Since18 Jan 2019, i see my house dragging with no big change. Our understanding is only below items are remaining and they are still not done: -Splash-back - Finishings touches - House Cleaning I am not a builder and might not know great deal, but all this is making me unsettled. As first time builders we did not see during contract signing what was the number of days Wisdom needs to inform us about PCI. It seems its only 6 days. so they said they have to only inform us 6 days before PCI. We also did not see how much fine they would pay for every day of delay (which i think was left at default which is $15). Also I have one more concern, We had 2 linear air con vents in living area. While all the rest of vents are done, this is not. And I am worried why not. Did any one had this kind of experience. Also My SS who was giving me exact updates seems to be giving me very tentative words like near PCI and no exact dates. It seems we are just put on hold while Wisdom is finishing other projects or working on new ones. This is making my Wisdom experience really very bad. Hi Kvav27 We also got delayed in terms of handover. Especially because the handover dint happen before Christmas and then there was 3 weeks of no activity. Followed by very little. Finally we got our keys 2 days back when ideally we were expecting it jan mid. Keep pushing for the updates and escalate to your area manager if required Re: Building with Wisdom Homes 14165Feb 16, 2019 6:22 pm M4bath For those who are in the north ryde area, any recommendation for an arborist? Got 1 tree that needs a report whether we can remove it. Thanks! Bradshaw Trees. Highly recommended Re: Building with Wisdom Homes 14166Feb 17, 2019 10:44 am Hi, We received an email from CQ during the week saying that our sparky has asked to move the light switch at the base of the stairs either to the study wall or around the corner behind the wall. Neither of which is desirable. Has anyone else encountered this? What heights are the light switches normally at? As the handrail is about 1000mm the switch should be able to be above this about 1300mm? Re: Building with Wisdom Homes 14167Feb 17, 2019 12:13 pm ml117 Hi, We received an email from CQ during the week saying that our sparky has asked to move the light switch at the base of the stairs either to the study wall or around the corner behind the wall. Neither of which is desirable. Has anyone else encountered this? What heights are the light switches normally at? As the handrail is about 1000mm the switch should be able to be above this about 1300mm? Why does it need to move? The handrail is in the way? Where is the study? Re: Building with Wisdom Homes 14168Feb 17, 2019 12:16 pm becks81 ml117 Hi, We received an email from CQ during the week saying that our sparky has asked to move the light switch at the base of the stairs either to the study wall or around the corner behind the wall. Neither of which is desirable. Has anyone else encountered this? What heights are the light switches normally at? As the handrail is about 1000mm the switch should be able to be above this about 1300mm? Why does it need to move? The handrail is in the way? Where is the study? They have said the handrail is in the way. Study is room across from the base of the stairs. Really want it in the most practical spot. Re: Building with Wisdom Homes 14169Feb 17, 2019 9:30 pm Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks We have one too and that's likely the sitting directly under your bath tub. It's to access the plumbing from under the bathtub Re: Building with Wisdom Homes 14170Feb 17, 2019 9:37 pm doosra Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks We have one too and that's likely the sitting directly under your bath tub. It's to access the plumbing from under the bathtub Hi doosra, Thank you for your reply. The bathtub ones are in garage and in bed5 for me. They didn’t put an outlet in dining at all. Instead they put in the walkway. So no airflow in dining. Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 14171Feb 17, 2019 9:40 pm We got the posession of the house. Am happy with tiling and kitchen. But am very dissapointed with the doors windows and external finishes. Especially the grout and area between bricks and doors and windows is not sealed off neatly. This kind of finishing is not expected from apremium builder like Wisdom. Do any of you have any issues like this. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 14172Feb 17, 2019 9:44 pm Priyasuresh11 doosra Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks We have one too and that's likely the sitting directly under your bath tub. It's to access the plumbing from under the bathtub Hi doosra, Thank you for your reply. The bathtub ones are in garage and in bed5 for me. They didn’t put an outlet in dining at all. Instead they put in the walkway. So no airflow in dining. We have one right between fridge and kitchen island. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 14173Feb 17, 2019 10:03 pm Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks I have linear outlets in the drop ceiling with vent facing dining. In other cases, they should put a vent in dining near the window. Do you have a plan from Actron? Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 14174Feb 17, 2019 10:06 pm MandM+4 Kvav27 Hi All, We are still waiting and have no information about PCI, moreover when we went to the site today I got worried about couple if finishing details. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The grouting or finishing in here in these pictures looks very poor. Is this normal? Also below the outside step Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There is broken pieces of concrete and again us this normal finishing? All normal. Yeah, we had similar. the hanging power points are for down lights. Did you ask them to leave provisions - as I had similar and just pushed the cables in when I installed the downlights myself. Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 14175Feb 17, 2019 10:08 pm M4bath For those who are in the north ryde area, any recommendation for an arborist? Got 1 tree that needs a report whether we can remove it. Thanks! M4bath, I am in North Ryde, but sorry, dont know any arborist. Have you tried local classified/true local? Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 14176Feb 18, 2019 6:03 am singalg Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks I have linear outlets in the drop ceiling with vent facing dining. In other cases, they should put a vent in dining near the window. Do you have a plan from Actron? Hi Singalg, Yeah. If something is prohibitive to install in Dining they should have installed a linear one in the dropped ceiling. Yeah. I checked the plans. It is supposed to be closer to the dining window. Ultra air says there is L shaped beam around the room. But I can see the beam runs through the living room. But I am not sure how did they manage to put there!! Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 14177Feb 18, 2019 6:06 am Hi Doosra, I have one too on top of the sink like you. But you should have one in Dininh.Isn’t it? Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 14178Feb 18, 2019 7:20 am Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks You have a beam running along your dining room. Ultra air know this but when you go for you AC appointment they still indicate an outlet where your window is then you get the big surprise when you see it and they all run away blaming each other (Ultra Air/Wisdom) because they only like to communicate to each other at the Christmas party over a free feed and a beer. Re: Building with Wisdom Homes 14179Feb 18, 2019 10:21 am Manhattan52 M4bath For those who are in the north ryde area, any recommendation for an arborist? Got 1 tree that needs a report whether we can remove it. Thanks! Bradshaw Trees. Highly recommended Got it. singalg - sure. will also take a look at true local. the last time we did a general search, only found someone who does the trimming and removal, not the report itself. Re: Building with Wisdom Homes 14180Feb 18, 2019 3:22 pm calais Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks You have a beam running along your dining room. Ultra air know this but when you go for you AC appointment they still indicate an outlet where your window is then you get the big surprise when you see it and they all run away blaming each other (Ultra Air/Wisdom) because they only like to communicate to each other at the Christmas party over a free feed and a beer. Exactly. Terrible. Atleast they could have installed a linear outlet in the dropped ceiling. They didn’t do that either.I wonder is this their first ever project with beams???? Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73512 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8241 |
