Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 743Feb 12, 2019 6:39 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 744Feb 12, 2019 6:42 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 746Feb 12, 2019 6:52 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 750Feb 15, 2019 7:36 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 751Feb 15, 2019 7:37 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 753Feb 16, 2019 8:17 am Steve4216 Hi Michelle. We were originally going with tile flooring in the main living areas in our new build. When we went to a flooring company they showed us this product. Looks great in the showroom, waterproof, scratch proof. Sounds great. The only concern we have is how does it feel to walk on? We really dont like the hollow feeling we get when we walk on most other floating type floors. If it is a problem can there be an additional or upgraded underlay you can use that can help? Thanks for your help Hi Steve4216, you are talking about the Hybrids I assume. The Hybrids don't have an underlay, all it needs is on each plank. It has its own underlay attached to the backing. Possibly the reason you don't like the feel of floating floors is possibly you have been waking on thin boards. I recommend nothing less than 14mm and up for timbers and 12mm for laminates, this should get rid of any bounce in the boards, they are also a better flooring all round. The Hybrids are 6 to 6.5mm thick and are a strong system with no extra underlay for this flooring it should feel very firm to walk on, no bounce. It's quite a new flooring, we've done a couple of jobs in it, no complaints so far. As with every flooring, they all have their purpose. I give this system thumbs, second to loose lays from Karndean. De Novo Concepts Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 754Feb 16, 2019 8:28 am Here is one of my favourite well priced solution died nylon's. This has now put itself in the top 5 selling carpets in Australia. Well done "EC Group", this is a preferred nylon with us decorator's and designer's. It is a look alike to the the expensive pure wool loose loop pile that costs from $400 up to over $500 a L/M installed. Delano is priced at and between $215 to $220 depending where you buy it from. It maybe exclusive to Choices Flooring. Look's fantastic laid, just make sure not to drag furniture around on it with sharp bits on the carpet, you don't want to pull a loop!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ De Novo Concepts - Online Consultations - Build - Renovate - Decorate - Colour Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 755Feb 16, 2019 3:16 pm Michelle Steve4216 Hi Michelle. We were originally going with tile flooring in the main living areas in our new build. When we went to a flooring company they showed us this product. Looks great in the showroom, waterproof, scratch proof. Sounds great. The only concern we have is how does it feel to walk on? We really dont like the hollow feeling we get when we walk on most other floating type floors. If it is a problem can there be an additional or upgraded underlay you can use that can help? Thanks for your help Hi Steve4216, you are talking about the Hybrids I assume. The Hybrids don't have an underlay, all it needs is on each plank. It has its own underlay attached to the backing. Possibly the reason you don't like the feel of floating floors is possibly you have been waking on thin boards. I recommend nothing less than 14mm and up for timbers and 12mm for laminates, this should get rid of any bounce in the boards, they are also a better flooring all round. The Hybrids are 6 to 6.5mm thick and are a strong system with no extra underlay for this flooring it should feel very firm to walk on, no bounce. It's quite a new flooring, we've done a couple of jobs in it, no complaints so far. As with every flooring, they all have their purpose. I give this system thumbs, second to loose lays from Karndean. De Novo Concepts Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Michelle, Yes I was talking about the Hybrid flooring. We were looking at the Pryzm (by Armstrong Flooring). It's 6.5mm, it'll be interesting to see how they feel when walking on. We seen a 12mm premium laminate that was nice, but not as sturdy and waterproof as the hybrid ones. Link to the one we looked at https://www.armstrongflooring.com/resid ... pryzm.html Cheers Steve Re: I work in flooring - do you have a flooring question? 756Feb 17, 2019 9:15 am Steve4216 Michelle Steve4216 Hi Michelle. We were originally going with tile flooring in the main living areas in our new build. When we went to a flooring company they showed us this product. Looks great in the showroom, waterproof, scratch proof. Sounds great. The only concern we have is how does it feel to walk on? We really dont like the hollow feeling we get when we walk on most other floating type floors. If it is a problem can there be an additional or upgraded underlay you can use that can help? Thanks for your help Hi Steve4216, you are talking about the Hybrids I assume. The Hybrids don't have an underlay, all it needs is on each plank. It has its own underlay attached to the backing. Possibly the reason you don't like the feel of floating floors is possibly you have been waking on thin boards. I recommend nothing less than 14mm and up for timbers and 12mm for laminates, this should get rid of any bounce in the boards, they are also a better flooring all round. The Hybrids are 6 to 6.5mm thick and are a strong system with no extra underlay for this flooring it should feel very firm to walk on, no bounce. It's quite a new flooring, we've done a couple of jobs in it, no complaints so far. As with every flooring, they all have their purpose. I give this system thumbs, second to loose lays from Karndean. De Novo Concepts Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Michelle, Yes I was talking about the Hybrid flooring. We were looking at the Pryzm (by Armstrong Flooring). It's 6.5mm, it'll be interesting to see how they feel when walking on. We seen a 12mm premium laminate that was nice, but not as sturdy and waterproof as the hybrid ones. Link to the one we looked at https://www.armstrongflooring.com/resid ... pryzm.html Cheers Steve Morning Steve, Armstrong do a good floor. I don't know that one, but they are all pretty much the same structure. See if you can find it laid somewhere so you can walk on it. Good luck....can you show me some photos if you have it laid, I'd love to see. De Novo Concepts Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 757Feb 18, 2019 8:21 am Hi Michelle, We went into choices flooring to ahve a look at the Hybrid flooring. I liked the river gum in the Abode Noble (Karndean hybrid). But it was still not as dark as i want. Would you know of a color in a good hybrid product which probably matches an expresso or dark oak brown shade? Re: I work in flooring - do you have a flooring question? 758Feb 18, 2019 8:28 am Also, what do you think of Godfrey Hirst Hybrid flooring? How do you compare it with Abode Noble? Re: I work in flooring - do you have a flooring question? 759Feb 19, 2019 5:33 am Taniaimran Hi Michelle, We went into choices flooring to ahve a look at the Hybrid flooring. I liked the river gum in the Abode Noble (Karndean hybrid). But it was still not as dark as i want. Would you know of a color in a good hybrid product which probably matches an expresso or dark oak brown shade? Hi .... were I work, Choices Flooring Nowra, we only have the same Hybrids that you would have seen. I'm not sure if there is one out on the market dark enough for you. I'm guessing you will have to go looking, which I think you may have done. Companies may be going softly with the Hybrids to see how they go, more will come for sure. De Novo Concepts - Online Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 760Feb 19, 2019 5:36 am Taniaimran Also, what do you think of Godfrey Hirst Hybrid flooring? How do you compare it with Abode Noble? I haven't see the G/Hirst, we don't have that flooring. What you need to do is compare their core structure and backings. De Novo Concepts - Online Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39469 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3497 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10083 |
