When is your expected hand over date? We had our tradies working 9/1 I was shocked to say the least but pleased. We are up to filing and painting so hopefully finish a little earlier fingers crossed.
Browse Forums Building A New House Re: KDR - Allcastle Homes Grandworth 45 MK2 178Feb 15, 2019 1:36 pm check with your CDC cert at the last page. It list the OC requirement. For my case no need to do landscape, need vehicle access only (not necessary concrete) What hold me up is I have to get storm water certified work as executed by hydraulic Eng Re: KDR - Allcastle Homes Grandworth 45 MK2 179Feb 15, 2019 2:01 pm LevaneT check with your CDC cert at the last page. It list the OC requirement. For my case no need to do landscape, need vehicle access only (not necessary concrete) What hold me up is I have to get storm water certified work as executed by hydraulic Eng Awesome will check it. Your storm water was advised early in build correct I think you wrote about before Re: KDR - Allcastle Homes Grandworth 45 MK2 180Feb 15, 2019 3:36 pm All they need is to check if the storm water system are in according to the hydraulic design plan. For normal drainage design plumber should able to certify it. you also need to check with council for - Section 94 Contributions. Normally don't required for KDR of single house. At the end of CDC there should be a paragraph : conditions applying before the issue of OC Hi we are looking to talk to people who have built with them recently. We have signed mid range built contract but identified that a lot of things are not included.… 0 1741 Was the offer also on their website? If so, you could check the Wayback Machine. 1 1808 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 14238 |
