Browse Forums Building A New House Re: Shipping container home 9Feb 15, 2019 6:21 am After building the granny flat and moving on site we used the brick shed to prefabricate the steel post that the house will sit on. We are trying to use a lot of reclaimed materials and we managed to buy some old 200x200 shs steel. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ These are well and truly above and beyond the engineer's requirements but they were cheap and I like the look of large steel post and beams. We had to cut them to the right size, clean them up, weld them and finally get them galvanised. We tried a few different ways to cut the steel like a plasma cutter an oxy cutter and a 5 inch grinder. The oxy and plasma cutters were fast but not very accurate and ended up being quite expensive once you burn through all the consumable parts and gas. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ In the end we used the grinder as it was the most accurate. After welding new plates on the ends of the shs we had to drill 4 holes top and bottom to allow the zinc to flow in and drain out properly during the galvanising. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is important because galvanising is charged by weight so the more zinc that is trapped inside the more it will cost. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Shipping container home 10Apr 11, 2019 12:42 pm Next came the demolition of the brick shed. As we are trying to keep costs down we decided to knock the shed down by hand. This was a lot of work but cost us nothing. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We are also trying to reduce waste and the cost of removing it so we hired a mobile concrete crusher for about $1100 and over 2 days crushed 9000 odd bricks and roof tiles into useable gravel that we spread over our driveway. This will eventually be concreted after all trucks and cranes have finished on site. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Shipping container home 11Jul 05, 2019 3:44 pm Thanks for sharing, this is fascinating and inspiring! Keep up the good work. Re: Shipping container home 13Mar 06, 2021 11:27 am JonathanHodges There are some awesome ideas on this thread! You never realize how big these shipping containers are until you see one in person. In my opinion, houses like these would not be hard and expensive to build. The more I look into this the more I want to buy a few of these and start building a small house for myself. It would really make sense having something like this beside the house you already live in. I was looking online a bit and there are companies that can make you custom containers. The one that looked the most promising was https://www.tigercontainers.com/contact-us/shipping-containers-sydney/. It looked like they have a lot of experience, and they could be trusted. Hmmmmm... this sounds like a bit of masquerading self promotion. Particularly given the website dedicates all of one sentence to talking about modifying shipping containers to suit your needs. And no pictures etc to demonstrate they've ever done it. We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 8016 From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some… 2 6475 |
