Browse Forums General Discussion Re: Should the free standing cooker be higher than the bench 2Jan 31, 2019 11:53 pm My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Should the free standing cooker be higher than the bench 5Feb 12, 2019 6:37 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Should the free standing cooker be higher than the bench 8Feb 12, 2019 10:56 pm westbourne chippy The cooker is meant to sit 10mm above the bench height as per the installation instructions. People always want them to sit level however most upright cookers are meant to sit higher than the benchtop to minimise the potential for scorching of the top. Don't agree with you, chippy. The free standing cooker is the same height with the benchtop in many display homes. Professional installers can make them at the same level. You can google the prefect installation of free standing stove. My builder hire unprofessional and disqualified traders to do work because of low labour costs. It is not practical to home owners that the free standing cooker is higher with a big gap on both sides. Home owners are very difficult to clean up when food residues fall into the gaps from bencntop and cooktop. My builder said the gaps on both sides of the stove are for ventilation. It does not make sense to me at all. Builders always make excuses and won't bother to rectify. If you read the instructions it's very clear. See the line above the picture. It needs to be 10mm higher. I build kitchens so know what the requirements are from the manufacturers. That's the reason I'd never install an upright cooker in my own house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Should the free standing cooker be higher than the bench 9Feb 13, 2019 7:53 am Mine is about 100mm higher than my benchtop and find it is easier to clean the sides from possible spillages. Definitely the right height and makes sense. Confused Renovator Re: Should the free standing cooker be higher than the bench 11Feb 13, 2019 10:00 am DamNita Mine is about 100mm higher than my benchtop and find it is easier to clean the sides from possible spillages. Definitely the right height and makes sense. 100mm seems excessive, sure you don’t mean 10mm? Re: Should the free standing cooker be higher than the bench 14Feb 14, 2019 7:21 am Thanks for your response. You may be right but I really don't like the gaps on both sides of the stove. Very difficult to clean up the food residues when fell into the gaps. Re: Should the free standing cooker be higher than the bench 15Feb 14, 2019 10:03 pm You can't argue wrong with such a experienced installer who deals with thousands of kitchen installations over a lifetime, display homes are at times a home builders worst enemy with their in practical displays, so many unfortunate situations with most people thinking doing the display rounds is 99% of their homework when in fact it's barely doing anything as it's got almost no reality in what you can expect with trades, quality, service, communication, rectifications, actual building experience, it is the single biggest mistake most make, and since they have become so prominent so have poor builds. Re: Should the free standing cooker be higher than the bench 16Feb 15, 2019 9:22 am gillybean DamNita Mine is about 100mm higher than my benchtop and find it is easier to clean the sides from possible spillages. Definitely the right height and makes sense. 100mm seems excessive, sure you don’t mean 10mm? Yes Gillybean. Clearly an error and clearly you have lots of time on your hands. Confused Renovator Re: Should the free standing cooker be higher than the bench 17Feb 15, 2019 8:26 pm DamNita gillybean DamNita Mine is about 100mm higher than my benchtop and find it is easier to clean the sides from possible spillages. Definitely the right height and makes sense. 100mm seems excessive, sure you don’t mean 10mm? Yes Gillybean. Clearly and error and clearly you have lots of time on your hands. A simple yes would have sufficed rather than also adding the attempted derogatory remark at the end. Some people may have thought you knew what you were talking about. If being observant and knowing the difference between 10mm’s & 100mm’s, and taking the time to try and help others on a forum where I can, equates to having lots of time on my hands, then I have lots of time on my hands. 😂 Re: Should the free standing cooker be higher than the bench 18Feb 16, 2019 9:48 am westbourne Thanks for your response. You may be right but I really don't like the gaps on both sides of the stove. Very difficult to clean up the food residues when fell into the gaps. There will always be gaps. Smaller ones probably cause even more headaches. Larger ones as least u can have some stick to get things out. Regardless a lesson to readers. Don't install standalone cooktop. interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46800 2 15442 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31229 |
