Browse Forums General Discussion Re: So, I bought a 1950 bungalow...on my own....now what?!? 2Feb 12, 2019 6:49 pm Welcome. Best person for this job would be a handyman maybe air tasker or local paper. You'd drain the tank. If it's just a corrugated iron tank you can just cut it up with an angle grinder into manageable size. If it's been lined with concrete you'd have to cut off the tin external then break up the concrete. Once that's all done remove the base and piers. It's an easy job. How's access? If it's concrete lined you'll need a skip to chuck all the rubble into. That will need to be barrowed out. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: So, I bought a 1950 bungalow...on my own....now what?!? 3Feb 13, 2019 9:11 am chippy Welcome. Best person for this job would be a handyman maybe air tasker or local paper. You'd drain the tank. If it's just a corrugated iron tank you can just cut it up with an angle grinder into manageable size. If it's been lined with concrete you'd have to cut off the tin external then break up the concrete. Once that's all done remove the base and piers. It's an easy job. How's access? If it's concrete lined you'll need a skip to chuck all the rubble into. That will need to be barrowed out. Thanks Chippy. I didn't think of air tasker....never used it before. 'Bout time I tried. Thanks for the suggestion Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20432 9 24816 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19261 |
