Browse Forums Building A New House Re: What to do when the builder refused to rectify the defec 10Feb 12, 2019 10:17 am Benchtop height is 900 cm same as the plan. Stove on the kickboard height is 910 cm, 10 cm higher than the plan. But the builder said no take action. Re: What to do when the builder refused to rectify the defec 12Feb 12, 2019 2:12 pm I think with the sink, you will struggle to say its a defect, when you look online it clearly has the lip, which is likely for the drainer/chopping board accessory to fit into. Unfortunately its the ‘design’. Unfortunately it gets terrible reviews and Clark no longer sell it. Read the reviews on product review... When you compare a standard under mount Clark sink you will see it doesn’t have the double lip, where as the Pete Evans sink has a double lip Re: What to do when the builder refused to rectify the defec 13Feb 12, 2019 3:02 pm The sink looks wrong - like it's an inset that they have undermounted, but if it is the correct model as gogo65 states then not much you can do. Our freestanding stove in our last house was slightly higher than the surrounding benchtop and was sitting on the base carcass of the cabinets with kickboard underneath. I have to say, the rental we are currently in has the freestanding cooker on legs and I'd take the slight height difference in benchtop over the dust/fluff/dropped food getting underneath any day! The gaps either side look pretty standard - get used to crumbs or liquids falling down the sides. If it bothers you, you could caulk it with clear silicone? I can't comment as far as legal/standards go, just experience. Re: What to do when the builder refused to rectify the defec 14Feb 12, 2019 3:38 pm A lesson I learn from here is never put a stand alone stove in between 2 benchtop because no way on earth there will be no gaps. And food stuff, water, oil can spill into the gap.. If you silicon it, it won't look nice. Re: What to do when the builder refused to rectify the defec 15Jun 03, 2019 9:43 am The stove looks correct. Australian standard is the benchtop a min 13mm below the Hob. The undermount sink also looks correct. Some model sinks do show the lip. If the template says that size, that's what they would have done. As for the gap down the side of the cooker. It does need a gap. It may be a little big, maybe 2mm to big. But I do not think it is a defect. I believe it would be within tolerance. Re: What to do when the builder refused to rectify the defec 16Jun 03, 2019 10:26 pm westbourne Kitchen planStove is the same level with benchtop in the planLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Defect 1. The top edges of the under mount kitchen sink is not covered by the bench top (i.e. sink edges and silicon under the benchtop can be visible).The site manager said that is how it is meant to be. The builder said that the kitchen benchtop has been cut out using the template which comes with the kitchen sink. The visible exposed lip around the sink is correct. The builder refused to rectify it. Under mount sinkIs the visible exposed lip around the sink not a defect?Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Defect 2 The freestanding cooker comes with no legs so it needs the kickboard underneath. But the cooker is higher than the benchtop after installation. They should be the same height so it is a defect but the builder said they will not rectify it. Cooker and benchtop is not the same heightIs it a defect when the cooker is higher than the benctop? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ properly installation?Stove is higher than benchtop and gaps on both sidesLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What should I do when the builder refused to rectify the defects? Please advise, thanks. The kitchen elevation shows continuous bench top with no free standing cooker. Either the drawing is wrong or the specification, in any case it's builder's mistake if builder provided the drawings. Mistake = defect Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What to do when the builder refused to rectify the defec 17Jun 04, 2019 11:35 am I think you are right to fight this, trust me the builder to always say it’s not a defeat when they know it is. They just don’t what to spend the money to fix it & with this one it’s going to cost them a new bench top. The first thing is the oven, was this the one they showed you at selections? Or did you upgrade to the stand alone? What they have in the drawings is a built in oven & cooktop not a stand alone oven & cooktop that’s why there is a height difference. The sink, the stone gays have cut the hole for the sink just a little bit to big 1-2mm that’s why you can see that lip. This is a Pete Evans sink Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is my sink that is under mounted also Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 1 9474 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8219 |
