Browse Forums Building A New House Re: Things you forget - summary page 32 1046May 19, 2018 10:50 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Things you forget - summary page 32 1053Sep 25, 2018 12:54 pm http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Things you forget - summary page 32 1054Sep 25, 2018 2:43 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Things you forget - summary page 32 1059Jan 22, 2019 8:20 pm Melbournevic Hi all, We're having 3122mm x 1200mm island bench however in our NHP (new home proposal) it says: A join may be required in the bench top and will be located as per suppliers recommendations. I have requested with our CSR to indicate in the NHP that the Client is requesting no join. I was told that they cannot omit that wording as it will depend on the bench length as well as the supplier's availability during that time. Can anyone please advise? Have you also requested no join on island bench in your NHP? I don't want to risk it as I may end up having an island bench with a join. Thanks I’ve always read that anything over 3m has to have a join. Can you reduce bench to 3m if you really don’t want the join? Re: Things you forget - summary page 32 1060Jan 22, 2019 8:43 pm shokel1975 Melbournevic Hi all, We're having 3122mm x 1200mm island bench however in our NHP (new home proposal) it says: A join may be required in the bench top and will be located as per suppliers recommendations. I have requested with our CSR to indicate in the NHP that the Client is requesting no join. I was told that they cannot omit that wording as it will depend on the bench length as well as the supplier's availability during that time. Can anyone please advise? Have you also requested no join on island bench in your NHP? I don't want to risk it as I may end up having an island bench with a join. Thanks I’ve always read that anything over 3m has to have a join. Can you reduce bench to 3m if you really don’t want the join? Thanks shokel1975, I thought a 1 piece of stone is 3200mm in length. I'll check with them and reduce to 3m if it's the maximum. Should I still request them to indicate no join to make sure? Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11632 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8419 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6632 |
