Browse Forums Building A New House Re: Brick Issue with new house, rendering whole house, re-br 3Jan 18, 2019 3:42 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Brick Issue with new house, rendering whole house, re-br 4Jan 18, 2019 7:57 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Brick Issue with new house, rendering whole house, re-br 6Jan 18, 2019 8:10 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Brick Issue with new house, rendering whole house, re-br 9Jan 20, 2019 8:49 pm pareshkerai With Reference to above pictures, Hi All, New house build handover in April 2017. Having constant issue with bricks and manganese stains. When the house was getting built, builder pointed out inconsistency with brick colour, they were not uniform. On discussing with us and brick company, we ended up getting it painted, brick by brick by a company called Nawkaw. Since then we have had this ongoing problem with brown staining. The brick company has organised some sort of a special wash twice in the summer months saying this should fix the staining problem but each time, it takes the stains away and they re-appear after few months. See pictures attached. The brick company now seems to admit that there has been an issue somewhere and working with me on a resolution. The builder is also involved and seems to working in out interest to sort things out. Brick company is toying some options like rendering the whole house! Builder and I were discussing stripping the bricks and re-bricking again, he said this would be his first time on that and unheard of in normal practice. Builder suggested to consider some sort of cash settlement. House size is about 245sqm. We are not keen on render at all and are worried about the re-bricking side of things - we feel it may fix the brick issue but would be a big hassle and perhaps leave many other things windows, doors etc damaged. Just hoping to get some suggestions on what to do. We are thinking of first getting a 3rd treatment done and get it all painted by nawkaw and wait several months to see if it fixed it. If not, we are not keen on render but may look towards a cash settlement. If so any experts out there what range this cash settlement should be in? I feel it should atleast match the cost of re-bricking the house - materials and labour - the bricks are PGH mist brick, would someone be able to estimate what cost this would be? Any suggestions would be appreciated. Please let me know if need more information. Re: Brick Issue with new house, rendering whole house, re-br 10Jan 21, 2019 8:36 am Searching4 knowledge pareshkerai With Reference to above pictures, Hi All, New house build handover in April 2017. Having constant issue with bricks and manganese stains. When the house was getting built, builder pointed out inconsistency with brick colour, they were not uniform. On discussing with us and brick company, we ended up getting it painted, brick by brick by a company called Nawkaw. Since then we have had this ongoing problem with brown staining. The brick company has organised some sort of a special wash twice in the summer months saying this should fix the staining problem but each time, it takes the stains away and they re-appear after few months. See pictures attached. The brick company now seems to admit that there has been an issue somewhere and working with me on a resolution. The builder is also involved and seems to working in out interest to sort things out. Brick company is toying some options like rendering the whole house! Builder and I were discussing stripping the bricks and re-bricking again, he said this would be his first time on that and unheard of in normal practice. Builder suggested to consider some sort of cash settlement. House size is about 245sqm. We are not keen on render at all and are worried about the re-bricking side of things - we feel it may fix the brick issue but would be a big hassle and perhaps leave many other things windows, doors etc damaged. Just hoping to get some suggestions on what to do. We are thinking of first getting a 3rd treatment done and get it all painted by nawkaw and wait several months to see if it fixed it. If not, we are not keen on render but may look towards a cash settlement. If so any experts out there what range this cash settlement should be in? I feel it should atleast match the cost of re-bricking the house - materials and labour - the bricks are PGH mist brick, would someone be able to estimate what cost this would be? Any suggestions would be appreciated. Please let me know if need more information. IMO, I'd press for re-bricking, the windows and door frames would have been installed prior to the house been bricked so peeling then off shouldn't be a problem. If you do go for render, insist on a proper cement render, not acrylic as the cement is a much more even and cleaner finish. I read cement render can crack more often compare to acrylic. Is that true? Re: Brick Issue with new house, rendering whole house, re-br 12Oct 23, 2019 11:01 am Renfar Hello, just wondering what you decided to do. We are currently in an identical situation and not sure which way to go. I HAVE THE PERFECT SOLUTION!! Pulling the bricks off is a near impossible and if you dont like render then brick biscuits are the way to go. We are using them on an apartment project we are doing and sticking them onto the blockwork. Made from real bricks just cut thinly. see the website below https://www.empirebrick.com.au/ Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Brick Issue with new house, rendering whole house, re-br 13Oct 28, 2019 12:14 pm SejaeD Renfar Hello, just wondering what you decided to do. We are currently in an identical situation and not sure which way to go. I HAVE THE PERFECT SOLUTION!! Pulling the bricks off is a near impossible and if you dont like render then brick biscuits are the way to go. We are using them on an apartment project we are doing and sticking them onto the blockwork. Made from real bricks just cut thinly. see the website below https://www.empirebrick.com.au/ ta Re: Brick Issue with new house, rendering whole house, re-br 14Oct 28, 2019 12:17 pm Renfar Hello, just wondering what you decided to do. We are currently in an identical situation and not sure which way to go. Hi Renfar, still an ongoing issue atm. They are currently exploring further treatments. The last applied is a product called MVR from Guard It via Buildpro. Some sort of sealer was applied before which they reckon should fix the issue. The MVR left a different color stain so now they are repainting each brick by brick to a colour that is acceptable to us. Still in trial and error. If this doesn't fix then we will accept render of whole house with probably a written agreement for a 20yr maintenance period - cracking/repainting etc Re: Brick Issue with new house, rendering whole house, re-br 15Nov 06, 2019 11:02 am We have just tried the same things. First it was MVR on its on. Next they tried a sealer followed by MVR. staining is coming back through. May I ask what this painting they are trying is? We are most likely looking at knocking down the bricks and doing the brickwork again but this poses a whole new set of problems not to mention extreme inconvenience to my family having to move out while they do this Re: Brick Issue with new house, rendering whole house, re-br 16Nov 06, 2019 11:18 am Renfar We have just tried the same things. First it was MVR on its on. Next they tried a sealer followed by MVR. staining is coming back through. May I ask what this painting they are trying is? We are most likely looking at knocking down the bricks and doing the brickwork again but this poses a whole new set of problems not to mention extreme inconvenience to my family having to move out while they do this Hi Renfar, I have enquired and they are getting back to me, I will chase up again and get back to you. So far they have only painted about 4 lines of brick about 2 metres look. The look is good but waiting now to see if the problem will reappear. If it holds then they will paint up the whole house and I will be asking for a written guarantee of 20 years that if problems presents they will action. If this fails then render is what we will accept. During construction, when it was identified that brick colour was inconsisitent, at that time they had nawkaw.com.au come up and paint the bricks whole house - we just picked a batch of colour we liked and they matched it. The current paintwork colour wise is quite similar but finding out what company/product it and will get back to you Re: Brick Issue with new house, rendering whole house, re-br 17Nov 06, 2019 9:49 pm pareshkerai Renfar We have just tried the same things. First it was MVR on its on. Next they tried a sealer followed by MVR. staining is coming back through. May I ask what this painting they are trying is? We are most likely looking at knocking down the bricks and doing the brickwork again but this poses a whole new set of problems not to mention extreme inconvenience to my family having to move out while they do this Hi Renfar, I have enquired and they are getting back to me, I will chase up again and get back to you. So far they have only painted about 4 lines of brick about 2 metres look. The look is good but waiting now to see if the problem will reappear. If it holds then they will paint up the whole house and I will be asking for a written guarantee of 20 years that if problems presents they will action. If this fails then render is what we will accept. During construction, when it was identified that brick colour was inconsisitent, at that time they had nawkaw.com.au come up and paint the bricks whole house - we just picked a batch of colour we liked and they matched it. The current paintwork colour wise is quite similar but finding out what company/product it and will get back to you Which company is giving the 20 year guarantee, If it’s the brick manufacturer then likely that’s ok. But if the builder or another company, whose to say they will still be operating in 20 years time? Re: Brick Issue with new house, rendering whole house, re-br 18Nov 07, 2019 6:24 am Hi, The main issue with staining on brickwork is efflorescence. Moisture bring salts to the surface. No “coating” will stop it properly, can really only clean off and wait, repeat or replace. If its coming through paint/stain then would come through render over time IMO re-bricking is the only solution. It will involve quite a lot of ancillary work like removal of eaves, downpipes, power outlets etc and repainting reassemble. Thnks Re: Brick Issue with new house, rendering whole house, re-br 19Nov 08, 2019 1:12 pm Mirrmu83 Hi, The main issue with staining on brickwork is efflorescence. Moisture bring salts to the surface. No “coating” will stop it properly, can really only clean off and wait, repeat or replace. If its coming through paint/stain then would come through render over time IMO re-bricking is the only solution. It will involve quite a lot of ancillary work like removal of eaves, downpipes, power outlets etc and repainting reassemble. Thnks Hi Mirrmj83, We tend to agree that a re-brick is going to be our only option at this point but we are concerned how doing this job would impact us given we are already living in the house. Could I pick your brain and ask what questions we should be asking the builder re the process and what things you think we should look out for during same. Re: Brick Issue with new house, rendering whole house, re-br 20Nov 09, 2019 9:03 am Hi, You are basically undertaking demolition and rebuild. This is not uncommon and will be very prevalent when the flammable cladding projects in Victoria commence. Going to have to catalogue a lot of things. Condition reports, 300+ photos of driveways, landscaping,, windows/doors, internal plaster. One thing to consider would be having the brick ties installed with screws instead of nails as the continue hammering of nails to frame could cause cracking to internal plaster. The builder may have to engage security to patrol/guard house from 5pm - 7am for the period when the bricks have been removed and the relaying begins. Instal CCTV., temporary toilet etc Have to have an agreement on lintels (reuse or new), everything which is removed that can go back on. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4912 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7567 |
