Browse Forums Building A New House Re: New Home on Block with 2.5m fall 16Jan 15, 2019 11:53 am We had a 4_5metre fall, worked out better more cost effective to go one level with garage, laundry under neath and a massive 3 times the garage storage space off garage, we done retaining walls and had raft slab in garage and brick pylons with strip footings, we doubled all our brick pylons for safety, no problems and house on same level very practical, this for us worked out more cost effective with quality work. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New Home on Block with 2.5m fall 18Jan 21, 2019 4:08 am We bit the bullet and bought the block, convenience and location was ideal for our circumstances. Now to work with the land and find a builder to help build our home. Thanks all for the valuable advice. I will be using this thread to update as i go along, Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4715 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18432 AS4654.2-2012 External Membranes it is "Informative" but if you get water ingress your insurance assessor will go to this straight away and if not achieved, they will deny… 9 1937 |
